Help from high octane users & fuel pump problems
Hi fellow 6speedians...I was out yesterday (actually to fill the tank for some extended garage time), filled my tank and on the way home...fuel line ruptured...again. I am now on my 4th fuel pump.
So my question/poll to all users of high octane gas (I use VP100)...anybody had any fuel pump issues?
Also to those with fuel pump issues...what octane and type of gas are you using?
Thanks much brothers!
Update: I spoke with the technical director at VP fuels... he said the VP100 (what I am running) has the same oxygenators as pump gas. He did indicate that, especially for cars that sit, the ethanol in the fuels will corrode European fuel lines over time. He suggested getting an American made hose or using a non-oxygenated fuel (C10 for example).
i just replaced my fuel pump after 25k miles. it wasn't the stock one though - whatever comes w/ GT700. the fuel pressure was slowly falling over time.
i used 100 octane (not sure of brand, will get that for you later) 90% of the time. car has become a weekend car this past year.
- chuck
- chuck
- chuck
- chuck
Jag
The problem is not actually the pump...it is the hose...the hose is splitting as a result of it deteriorating from something...I don't think it is ethanol as that is everywhere...any other thoughts?
GT 700 Includes:
-EVO Modified Garrett GT700 High Flow turbochargers
-Upgraded high pressure wastegates
-CNC machined billet aluminum wastegate mounts
-EVO Billet Diverter Valves
-EVO Proprietary /GIAC GT700 Software
-EVO / Milltek Sport Stainless Steel Exhaust w/ 100 Cell Catalysts
-EVO V-Flow Air Induction System
-EVO 41.5 mm Primary Tube Stainless Steel Headers
-EVO / Sachs Stage 3 Clutch (Can use with Dual Mass Flywheel)
-EVO Silicone Boost Hose Conversion w/ Diverter Valve "F" Hose
-EVO 70mm High Flow Turbo Air Inlet Ducts (plastic)
-EVO Braided and Fire Jacketed Fuel Line Upgrade Kit w/ Fuel Filter Kit, Adapters, Clips
-EVO Modified Fuel Rails
-EVO High Flow Fuel Injectors
-Bosch Spark Plugs
-EVO GT700 Floor mats
-EVO GT700 CNC machined hood badge
You must be special:
GT 700 Includes:
-Bosch Spark Plugs
GT 700 Includes:
-Bosch Spark Plugs
.They must have changed it since 3 years ago because i definetely recieved a new pump .Screwed up my damn fuel gauge and ran out of gas!
Doesnt matter either way the badge, mats, and gt3 seat inserts with the gt700 logo have to go
Anyone want to buy this stuff? I have the gt3 seat inserts in black w/ white lettering and red w/ black lettering. The black one have never been used.Jag
But then they both probably run different pressure... I think todd K runs a 4.2 bar FPR ....
2001 996TT 3.6L and stock ECU
Hey, sorry to hear you're having fuel line problems.
I've been running VP MS109, and have not had any problems (knock on wood).
I recall Todd Z himself satting that the stock pump can handle 700 hp.. that is why they do not change it. It was on a thread that somoeone brought up Protos dual 044 pumps in series... and I recall Todd Z responding that it's not required.
Honestly there this sounds like bad luck or kind of installation problem if you're really no your 4th pump. I've never heard of such an issue and I've put about 30k miles on my audi with blended E85. Which line is rupturing exactly?
