Where do you stop 700,800,900,1000 HP ?
Old Dec 13, 2007 | 07:20 PM
  #31
DMaffo's Avatar
DMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud of
RCNJ....
I hear ya on the power thing... I did hear about the k24/20g set up...but.... its sooo close to what we have.... that...
i dont know...doesnt sit too well with me.... on the other hand....I love the idea of having a car like markski.... his car hauls bro!! lots of $$ and time and down time and more $$ and some more tuning...etc etc... BUT DARN quick!!! and virtually no lag... crazy top end.. ID probs melt that motor coz Id be out on every hwy trying to top it out... either that or id be on 6 oclock news on national tv as the first maniac trying to outrun the police chopper....!!! lol!!!!
Old Dec 13, 2007 | 07:27 PM
  #32
RCNJ's Avatar
RCNJ is infamous around these parts
I usually call it a day once I have my car completely wrapped around a pole in a U shape! LOL, we need to hit the next AA meeting (Automobile Anonymous).
I'll race you there!
Old Dec 13, 2007 | 07:28 PM
  #33
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
RCNJ, good luck with the new engine build. It will be more expensive, take longer and be more frustrating that you plan. Do it once and do it right. The labor to go in is ridiculous so you are almost obligated to replace or upgrade anything marginal while you are in there. Check your intermediate shaft and bearings while in the motor. Replace the liner O rings as well. Check for updated seals and sealants. Spring will be here before you know it, Dont be afraid of TopGun, he drives like a Granny
Old Dec 13, 2007 | 07:29 PM
  #34
TonyNJ's Avatar
TonyNJ is a glorious beacon of lightTonyNJ is a glorious beacon of lightTonyNJ is a glorious beacon of lightTonyNJ is a glorious beacon of lightTonyNJ is a glorious beacon of light
I'm here already! I'll get you some coffee.
  #35
Y65MPH's Avatar
Y65MPH is infamous around these partsY65MPH is infamous around these parts
You know my thoughts. 3.8L to 4.0L twin plug, big heads, big case work, GT35R's. 1000 HP BABY!!!!! Maybe you can pull the front wheels off the ground at 80 MPH. Oh yea, and a big bill!!!
NEW PLATE: I8AVIPR
Old Dec 13, 2007 | 07:32 PM
  #36
RCNJ's Avatar
Originally Posted by DMaffo
RCNJ....
That sounds like one of are regular meets.
Markski's car is on a whole other level for sure.
  #37
topgun's Avatar
topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !
Originally Posted by Y65MPH
NEW PLATE: I8AVIPR
aren't you guy's freinds .....
Old Dec 13, 2007 | 07:34 PM
  #38
TonyNJ's Avatar
NEW PLATE: I8AVIPR
I think a better plate would be: I8AVISA
Old Dec 13, 2007 | 07:36 PM
  #39
topgun's Avatar
Raudel,
There will be a few bad boys this spring, (Suman, joetwint, Airjordon,RPM,topgun, Srt8) get her ready! We will have a ball!
Last edited by topgun; Dec 13, 2007 at 07:37 PM. Reason: the black choppers are coming!
Old Dec 13, 2007 | 07:38 PM
  #40
Originally Posted by topgun
When you have an EBC or external wastegates you remove that ability from the ECU...It's only so much timing the ECU can pull. They still make big power though!
YEs but bad gas and or running to much boost can cause a kaboom as well- even with internal Wgs and stock controller. I recall I used to have 3 sets or wgs... actually from a very respected( by me) tuner and boost still went up to 1.5 or 1.6 bars even though I had a Giac ECU. This happens when the Temps drop a lot and the boost natually climbs.... You almost would have to manually turn down the springs... somehting I did for over 6 months.
The ecu, as far as I know will not limit your boost via stock Wgs... its where ur Wgs are set is where the boost will peak... an if u had them set in the summer for 1.2 bars... well guess what... at 40 degrees or lower you will be doing 1.4 bars... thats why a lot of guys with upgraded springs go into limp mode when temps drop.
mark
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
  #41
RCNJ's Avatar
KPG, thanks for the tip. I'll make sure to run that by my builder. Hopefully come spring I'll be ready to drive Ms. Daisy .
Old Dec 13, 2007 | 07:43 PM
  #42
KPG's Avatar
KPG
Sure it will. That is how it works. The ECU sends a signal to the N75 valve to open the wg's and bleed off boost to prevent overboosting and overspinning of the turbos due to temp changes, boost hose failing etc.
Old Dec 13, 2007 | 07:44 PM
  #43
DMaffo's Avatar
race me there..??? I dont even have a car now....lol....!!! dont worry!!! ill come up with something!!!
Old Dec 13, 2007 | 07:47 PM
  #44
KPG's Avatar
KPG
Raudel, I made it a point to learn about my motor and find out what makes it tick inside. It is a whole lot easier to understand when you can touch the parts you are talking about. It would not hurt to take a good look at the lifters as well, my intake lifters were scored pretty good after only 18,000 miles, but hell, for all I know it was a lease return from Dmaffo Porsche is damn proud of their rebuild gaskets and orings as well.
Old Dec 13, 2007 | 07:48 PM
  #45
topgun's Avatar
mark
That is a good example! lets say your boost controller goes bad & spikes to 2 bar on pump gas then what? Sometimes its just not the gas...I prefer all the saftey measures I can get..IMHO
