GT3 sway bar questions (996TT)
Old Dec 14, 2007 | 04:26 AM
TwinT's Avatar
TwinT is infamous around these parts
Hi guys,
I have ordered both the front and back GT3 sway bars for my 2003 turbo and I hope you can give me some advice on the following:
Thanks to 996TT_Stevo for helping out so far.
- can I use GT2 bushes?
- is it possible to fit the front sway bar also?
- what settings shall I use for road use?
- I am using stock droplinks for now but would like to upgrade at some point. what should I buy?
thanks for any help!
Lee
Old Dec 14, 2007 | 06:58 AM
heavychevy's Avatar
You mean bushings? Which bushings are you reffering to, subframe,control arm?
I would run the rear sway bar on full stiff (Assuming it's adjustable), and the front on full soft, in fact I wouldnt put the front GT3 one on the car (if they fit).
Old Dec 14, 2007 | 11:00 AM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Hi Lee, no probs, just run rear, you will be all good!
Old Dec 15, 2007 | 09:02 AM
silver's Avatar
silver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to all
Someone on here advised that running the gt3 bar on full stiff may contribute to breaking the drop links. I am running the stock drop links with the gt3 bar on the next to last stiffest. meaning 1 off of full stiff and have had no issues on several DE's. I'm sure full stiff does flatten out the lean even more though.
Old Dec 15, 2007 | 05:03 PM
dtmarsh's Avatar
dtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud of
Does anyone have a pic of a rear swaybar installed? Thx, David
Old Dec 15, 2007 | 06:11 PM
fly2low's Avatar
fly2low is infamous around these parts
drop links = Tarrett or TRG
Old Dec 15, 2007 | 07:23 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
have trg on the rear no probs the front is stock left it stock for a reason can't remember why... any ideas????
Old Dec 15, 2007 | 11:33 PM
Zippy's Avatar
I have rear at 1 hole off full stiff and the fron at 1 hole off full loose. Use ScarGo curved front drop link. I get a little clanking going over speed bumps at slow speeds.
Old Dec 16, 2007 | 02:53 AM
TwinT's Avatar
is there a DIY article anywhere?
thanks
Old Dec 16, 2007 | 05:54 AM
silvershark's Avatar
silvershark is infamous around these parts
End Links
Vivid racing (board sponsor) also offers quality end links.
The Agency power rear end links are the most massive I have seen.
Billet aluminum, heim joint and fair price...I have a pair on the H&R 24mm
rear sway and very satisfied.
Old Dec 16, 2007 | 05:57 AM
mose55's Avatar
mose55 is infamous around these parts
I have mine set in the middle for both front and back. The clearance with the drop links is tight on full compression if you want to put in stronger ones so installation and adjustments are key. My installer spent a few hours getting it right.
Old Dec 16, 2007 | 07:06 AM
TwinT's Avatar
fitted the rear on 1 away from full stiff.
good mod, I could notice the difference immediately.
have the front also so will get some drop links and fit this I think.
does anyone know the legnth of the front drop links?
Jul 29, 2019 11:13 AM
orbelo
Aug 30, 2015 12:26 PM
TrackOne
Aug 20, 2015 12:56 PM
