Radiator & coolant flush procedure
Old Dec 16, 2007 | 07:09 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Hey guys, I am replacing my front side radiators (both are leaking). I would like to know the proper way of flushing and bleeding. Is there any bleed screws that need to be cracked in the system?
What type of coolant is to be used? I bought some Pentosin G001100 but i read somewhere that I need G12 instead?
Old Dec 16, 2007 | 09:22 PM
Turbohead's Avatar
Turbohead is just really niceTurbohead is just really niceTurbohead is just really niceTurbohead is just really nice
Don.
I havn't done it on TT but idid my NA 996 .it should be the same.
Drain system completely by opening the coolant hose and coolant drains in the back if the engine under fill bottle.
look up capacity
That way you will know that you are geting th proper 50/50 mix.
Jack the rear of the car high so that the air bleed out of the fill bottle . add coolant mix slowly when it fills, start the engine for a little bit so thermostat opens and add more. Let air bubbles come out .you may have to do it several times.
Keep track of the amount that goes in so you will know when it is full and all the air is out. patience!
I used Prestone DEX-Cool Equiv.
Old Dec 16, 2007 | 10:00 PM
BigBadBen's Avatar
BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !
Go to your local Audi dealership and pick up the coolant from them, yes it's a different colour to the p-car stuff but it is the same spec and half the price.
I have had to bleed my system 6 times now and that is what I use. I also picked up a Snap-on Tools pressure bleeder that ensures there are no air locks in the system.
This is one of the best tools I own. It is called RADKITPLUSA.
Cheers,
Ben
Old Dec 17, 2007 | 03:01 PM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
Slightly OT: has anyone replaced the thermostat with a cooler one? I'd like for my car to run a bit cooler and this was always a good little mod on previous cars.
Old Dec 17, 2007 | 05:16 PM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
Porsche coolant is 30 bucks a gallon and is 50/50 i.e. 1 gallon of coolant plus 1 of HOH. The benefit to the Porsche stuff is that it is lifetime coolant, so it is a one shot deal.
Don't shoot the messenger, I got this from the wrench at the dealership when asking if I really needed Porsche coolant - he said no by the way.......
Old Dec 17, 2007 | 07:01 PM
Turbohead's Avatar
You don't want to run a cooler temp in this engine.
the ECU adjusts everything based on temps, and these cars don't overheat unless something is wrong.
Cheers
Old Dec 17, 2007 | 08:05 PM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
Cheers,
Ben
Ben is right,the best way to do it is with a bleeder........you will go nuts trying to get the air out otherwise.Joe
Old Dec 17, 2007 | 08:25 PM
Joe Weinstein's Avatar
cooler is not 'cooler'. Oil is at it's best lubricity at 185 degrees.
Old Dec 17, 2007 | 10:31 PM
TKDalumni's Avatar
TKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really nice
Just out of curiousity...How long should this take?
Old Dec 18, 2007 | 10:23 PM
TKDalumni's Avatar
Wow! Takes that long, huh?
Old Dec 18, 2007 | 11:27 PM
BigBadBen's Avatar
20 minutes maybe so long the you have a large enough compressor.
Old Mar 19, 2009 | 08:42 AM
joyride's Avatar
joyride has a spectacular aura aboutjoyride has a spectacular aura aboutjoyride has a spectacular aura about
What is the best way to flush ALL coolant out of the system?
I have a RADKITPLUSA bleeder.
Old Mar 19, 2009 | 09:23 AM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
Cheers,
Ben
+1 Have done it without the Radkitplus and it was an absolute hell. With the kit much easier.
Old Dec 2, 2011 | 08:48 PM
Hurdigurdiman's Avatar
Hurdigurdiman is infamous around these parts
I just found the best site yet on how to completly flush out the cooling system on a Boxer... Ok I have a 1999 C2 996 and it must be the same process or as near as dammit is to cursing. Now I can buy U-View 55000 Air Lift Vacuum and Cooling System Tester and Refiller from Amazon for $119 (free shipping) for refilling the system.
Check it out. Theres all kinds of good DIY projects on the same site. Great photos and explanations. http://pedrosgarage.com/Site_3/Flush...nt_System.html
Old Dec 2, 2011 | 09:22 PM
RennFab's Avatar
RennFab is a glorious beacon of lightRennFab is a glorious beacon of lightRennFab is a glorious beacon of lightRennFab is a glorious beacon of lightRennFab is a glorious beacon of light
Porsche, Audi, VW, and BMW all use the same coolant makeup....it just has different dyes in it. They're all lifetime coolants now. HEPU(G12) variant is the cheapest at about $9 per 1.5liters(100%, mix 50/50 to make 3 liters) it's just blue. Just best not to mix different colors as it turns green/brown and makes it difficult to distinguish it from bad coolant.
