New Codes
Old Dec 18, 2007 | 11:56 AM
  #31
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
spoke wth alex and he said running 101 in race is probably the problem. I will set the car to pump and run the 101 and from now on only run 109 in race.
Joe I will not run it hard anymore and get it to alex
Old Dec 18, 2007 | 12:48 PM
  #32
topgun's Avatar
topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !
Good Luck!! Joe gave you the best advice , If you have any damage you keep it to a minimum...& yes 101 is Good for stock cars only...
Old Dec 18, 2007 | 01:05 PM
  #33
jags911tt's Avatar
Jag
Old Dec 18, 2007 | 03:50 PM
  #34
That is why I originally asked Jeggs what "Race fuel" was when he mentioned he ran 1.5 bars one race gas.
101 is not good enough atn those levels...
he might has simply messed up the plugs etc..
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Dec 18, 2007 | 04:07 PM
  #35
jags911tt's Avatar
markski
Markski its Jag BTW I am dropping the car off in the first week of Jan. Hopefully Sumans car will be done too and I will decide whether to add soem gt30's or gt35's
Jag
Old Dec 18, 2007 | 04:27 PM
  #36
pgcanillas's Avatar
pgcanillas is infamous around these parts
Jag,
Excuse my ignorance and my english, but do you have a Durametric? Doesn´t it allow you to log detonation? Or the O2 readings in order to know if you are running lean?
Old Dec 18, 2007 | 04:33 PM
  #37
pgcanillas's Avatar
Joetwint,
Can you explain me what is a bung? Is it a capacitor? And how do you bung the O2? I am doing a catless exhaust, that I will be installing in the first days of January. I know that I will have CELs, but should the car run well if I do not do a flash? Or should I will go into a Limp Mode or something like that? THANKS!!!.
Old Dec 18, 2007 | 05:48 PM
  #38
killerbee's Avatar
killerbee is infamous around these parts
This is a bung:
http://store.summitracing.com/partde...5&autoview=sku
Drill a hole in exhaust after the turbocharger before the cat (assuming they are there). Regardless weld this fitting in place over hole, thread in wideband O2 sensor and you are ready to measure AFR.
Old Dec 18, 2007 | 05:49 PM
  #39
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
Originally Posted by pgcanillas
Joetwint,
It is an extension for the O2 sensor that gets screwed into the exhaust before the o2 thus picking it up and out vof the airstream.....basically fools the sensor.
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
PelicanParts.com
997 Vendor Classifieds
Oct 5, 2015 01:07 PM
Oct 2, 2015 02:23 PM
nagual911
Oct 1, 2015 01:52 AM
