Coolant Warning...
Old Dec 20, 2007 | 06:45 PM
996TTDave's Avatar
996TTDave has a spectacular aura about996TTDave has a spectacular aura about996TTDave has a spectacular aura about
Coolant Warning...
[edited_ ]
Old Dec 20, 2007 | 06:48 PM
MattMan's Avatar
MattMan is infamous around these parts
kaboom
Old Dec 20, 2007 | 06:53 PM
are you leaking fluid? if so u may have lost a rubber hose like I did twice...
if ur dry underneath then ur OK. fill it up.... let it warm up watch the guage again and look underneath to see if its leaking...
If you want can help you if ur not too far away.
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Dec 20, 2007 | 06:57 PM
AG996LV's Avatar
AG996LV is infamous around these parts
I think the flashing red light just means your low on coolant, not an overheating situation. Check it for leaks, could be the overflow tank.
Old Dec 20, 2007 | 08:08 PM
slant911's Avatar
slant911 is infamous around these parts
Check your coolant tank cap first. They are prone to premature failure.
Old Dec 20, 2007 | 10:07 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Check around your radiators. I had the same thing happen and found both my side rads leaking. If you cant find any leaks I would do a pressure check. Good luck
Old Dec 21, 2007 | 07:09 AM
vividracing's Avatar
Check the white plastic tank too, I have had my own crack and need to be replaced from leaking. hopefully it was just low.
Old Dec 21, 2007 | 11:57 AM
996TTDave's Avatar
[edited_ ]
Old May 17, 2008 | 11:11 AM
4G64T's Avatar
4G64T is infamous around these parts
Had a similar problem. The "Check Coolant Level" warning came on and red light near the top was blinking but there was no increase in engine temperature. I had to full up an extra 1 - 1.5L of radiator fluid, which is less than 5% of the total capacity (if it is 8 gallons). This all happen after I hit 299km per hour. I suspect a leak but have not check yet as I had to travel away from home. How strong are the radiators themselves? Do leaks come from the radiators or from the hoses?
Old May 29, 2008 | 03:56 AM
turbo73's Avatar
turbo73 is infamous around these parts
I had a similar problem. I topped up the water a couple of times over the last few months, and then when it was in for it's service and inspection, they noticed the front side radiators were leaking slightly. However, it wasn't dripping onto the floor as it was evaporating off due to the heat.
If there is a smell of 'hot coolant' when you park up after a drive I'd check this as well as the other guy's suggestions.
Good luck.
Old May 29, 2008 | 11:55 AM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
Shouldnt be burning coolant like that. I would compression and leak down as a safety measure. Last thing you want is a cracked head.
S
Glasgo
Nov 30, 2015 02:37 PM
freddiemac
Oct 7, 2015 11:05 AM
vkvmd
Oct 5, 2015 02:04 PM
flewis763
Oct 4, 2015 04:14 PM
