I just finished installing PSS9
Old Jan 6, 2008 | 08:24 PM
pcar993's Avatar
pcar993 is infamous around these parts
All im going to say is the car should have came like this from the factory. Here are a couple of pictures of the install in progress. More to follow as soon as i can take it out of the garage when the rain stops so i can take decent pictures outside.
Old Jan 6, 2008 | 10:07 PM
Superfly's Avatar
Superfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant future
Subscribed.
Old Jan 7, 2008 | 07:31 AM
atl123's Avatar
atl123 is infamous around these parts
Nice pics. Can you elaborate more? I know this topic has been done to death but every data point helps. I'm considering JIC's vs. PSS9's for street/track use, not lowered much. How much camber can you get with PSS9's alone without the camber plates like JIC? I've read the Renntech article on this replacement but looks like you had to remove the entire hub to do the fronts? Any other differences?
Old Jan 7, 2008 | 10:42 AM
pcar993's Avatar
I also used Renntech but there is a huge difference between C2 and C4/Turbo that is missed out in the article. With the halfshaft axle, you cant bend the lower arm down enough to get the strut out. You have to pull the carrier out to do it. Jeff (Midnight) helped me out it with that small detail that is left out from renntech. Thats why i show those 2 pictures. The rest you can follow renntech.
Old Jan 7, 2008 | 11:09 AM
wross996TT's Avatar
How do you plan on doing alignment and are you going to corner balance?
Old Jan 7, 2008 | 11:59 AM
pcar993's Avatar
Ill need to get it aligned and corner balanced. i've called afew places and wanted $600-700. They must be smoking crack. Thus my other rant/post about alignment.
Old Jan 7, 2008 | 12:10 PM
kermit_S's Avatar
kermit_S is infamous around these parts
Call up Arling at Lucent
Old Jan 7, 2008 | 12:26 PM
pcar993's Avatar
thanks, ill check them out.
Old Jan 7, 2008 | 01:48 PM
MidnighTT's Avatar
MidnighTT is infamous around these parts
When they were on my car, the front camber was set to -2, which was the most the tech could get. The rear ended up at -1.5, which was the lower limit (couldn't get less negative camber). This was using Bilstein's minimum recommended ride height.
Jeff
Old Jan 7, 2008 | 02:39 PM
IAPorscheDoc's Avatar
IAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond repute
You don't have to remove the carrier from the car on the awd cars. Bend the control arm down, lift teh carrier off the lower ball joint and move it forward of the control arm. Swing the strut downward to the rear and out. Pull the strut out of the carrier from there. You can leave the axle attached.
Old Jan 7, 2008 | 02:56 PM
pcar993's Avatar
Yes but you risk hitting your strut against the fender and plus its only 1 nut holding the carrier to the axle. It takes 1 mintue to take off with an impact gun. 1 extra minute can save alot of $$ and can be done with 1 person easily. No means putting you down APorscheDoc. Just looking at things from a different view.
Old Jan 8, 2008 | 12:22 AM
3rd Street's Avatar
3rd Street is infamous around these parts
i just installed these on my car as well...you're definitely right...should have this way from porsche. what a difference! definitely get it aligned and corner balanced from a porsche specialist (not the dealer/stealer)
3rd Street's Avatar
by the way...still waiting for updated pics
Old Jan 12, 2008 | 01:33 PM
Doc_Porsche's Avatar
Doc_Porsche is infamous around these partsDoc_Porsche is infamous around these parts
where's the car WITH the PSS9
Old Jan 12, 2008 | 03:28 PM
pcar993's Avatar
As promised, here are some pics after the PSS9 and wheel alignment.
