boost problem
Old Jan 10, 2008 | 12:18 PM
semih's Avatar
semih is infamous around these parts
boost problem
Hello everybody,
I have a 996 x 50 from 2003 and have 29000km and I ' m a normal driver.
When i drove my car earlier i always had 0.8 bar of pressure and the last two weeks i have 0.6 bar at wot and the car feels a bit slower after 4500 rpm. I have had a local mechanic looking at it and he said that the turbo 's couldn't hold the pressure. There is a little leak. Is this possible. He said that the diverter valve was ok. I still have the cpo extended warranty and have tomorrow an appointment with the cpo. And if the turbos are broken do the cpo cover it. MY car is fully standard and everything is original. Never did a racetrack to and I only drive the weekends and after a spiritid drive I let the turbo' s cool down for 1- 2 minutes. Greetings from belgium and excuses for the errors in the spelling.
Old Jan 10, 2008 | 01:14 PM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
There is a leak....Maybe the hoses. I would think the CPO does cover Turbos, but i dont think thats the problem.Good luck and let us know what they say is the problem
Old Jan 10, 2008 | 02:19 PM
Saint Ari's Avatar
Saint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud of
The car is fully stock?? Maybe that's teh problem ... you need a flash at least to get it to 1.2 bar ) LOL
Old Jan 10, 2008 | 08:02 PM
sttjmk's Avatar
sttjmk is infamous around these parts
Symptoms sound a lot like a boost leak. Last time I had a similar problem, (on a VW turbo), you could clearly hear the leak a different tone from the engine. Does it sound any different?
Old Jan 10, 2008 | 09:58 PM
Boost leak or limp mode but I doubt it.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jan 10, 2008 | 10:43 PM
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
I had the same symptoms...found a leak in the Diverter Valve....back to running at .9 to 1.0. Check for a leak like most of the suggestions tell you.
Old Jan 11, 2008 | 12:35 AM
Turbo Fanatic's Avatar
Could have a leaky diverter valve. Even if you get no mods, they are cheap insurance. Try a set of billet units.
Old Jan 11, 2008 | 01:33 PM
semih's Avatar
thanks for replying, today I went to pick up my car at the local mechanic and he said that he had done a minor thing to the bypass valve in the turbo and now I have 0.8 and 0.9 bar again. I went immediately after to the cpo (100 km trip ) and the car was going good. The cpo did a litlle check up and they couldn't find anything. What should I do . Any suggestions are welcome.
Old Jan 11, 2008 | 10:22 PM
If you're running .8 and .9, that's the sign of a healthy car. What you should do is drive it. Don't count on your CPO to cover everything. I was surprised to find out how many things are NOT covered. Major items such as your turbos and drive train would be covered unless you've done some mod they can point to as the potential cause of the failure.
Evan5469
Oct 29, 2015 06:39 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
nal991
Sep 11, 2015 09:05 AM
rsdub
Sep 10, 2015 03:30 PM
flewis763
Sep 10, 2015 01:08 PM
