Cat delete on Turbo...Pros and cons
Old Jan 25, 2008 | 09:32 AM
  #31
roadsterdoc's Avatar
Member
roadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to behold
Good thoughts. While nitrous or CO2 will do an incredible job of cooling, they can only be done in bursts or you will empty the bottle quickly. Water/methanol spraying is not effective if you do not have air going through the IC. So you need a scoop and/or a duct. Make a template out of cardboard. Once you have an acceptable design, use a thin aluminum sheet from the local hardware store and fasten it in place. If it doesn't get destroyed then you can fab a more permanent one from thicker aluminum.
Old Jan 25, 2008 | 09:41 AM
  #32
TXGold's Avatar
TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !
Good idea Chris.
Old Jan 25, 2008 | 10:11 AM
  #33
Gary in BR's Avatar
Gary in BR is infamous around these parts
Sounds like i will have a fun project next weekend.
I dont think this will make any noticeable dyno numbers but I will hook up my Gtech for pre and post op runs to see if there is anything noticeable there.
Old Mar 17, 2008 | 06:02 PM
  #34
contigo's Avatar
contigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant future
Twin turbo???!!! Who did it ??? HP aprox?
Old Mar 17, 2008 | 06:45 PM
  #35
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
I think it might be easier to swap it for a water intercooler.
Robert
Old Mar 17, 2008 | 09:59 PM
  #36
Gary in BR's Avatar
turbowerx did the design and install, I have about 235 hp at the wheels.
I have spoken to Marc some more about adding a scoop to my intercooler and he has a test scoop he will send to me shortly and we will see if there is a difference with the scoop.
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
jaehoppa
Oct 22, 2015 09:17 PM
MPM
Cayenne 955/957
Sep 20, 2015 08:22 PM
porschecayenne92
Cayenne
Sep 12, 2015 01:26 PM
