Improved handling from 20mm Spacers
Old Feb 10, 2008 | 01:26 PM
Zuma 911's Avatar
Zuma 911 has a spectacular aura aboutZuma 911 has a spectacular aura about
I was really suprised at the improved handling characteristics of the car by simply adding 20mm spacers in the rear. In addition, the car overall just looks meaner, I miss the steamroller look of the older models!! The next thing I need to do is lower it, as it is at 26.5" right now, due to my steep driveway issue onto the street.
And remember, when adding spacers always check the lug-torque after a short drive, the longer wheel bolts may stretch, thereby losing pre-load. It will sound like your wheel bearings are going bad....don't ask me how I know
Old Feb 10, 2008 | 01:32 PM
drh's Avatar
drh
drh has a spectacular aura aboutdrh has a spectacular aura aboutdrh has a spectacular aura about
I think it looks great, but you sure are brave adding the 20mm. I've got 15mm from Ruf.
Your front looks wider also, did you add spacers up there as well?
Old Feb 10, 2008 | 01:34 PM
Zuma 911's Avatar
Yup....7mm in the front.
Old Feb 10, 2008 | 01:54 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
Looks great. I have factory spacers on mine that came with the Sport Techno wheels.
Old Feb 10, 2008 | 02:04 PM
TT Tommy's Avatar
TT Tommy is infamous around these parts
Zoomer,
Wow!
for me, spacers (15mm front and rear) and a 1 inch drop transformed the look of the car by 100%
tw
Old Feb 10, 2008 | 02:11 PM
drh's Avatar
drh
Originally Posted by TT Tommy
Zoomer,
Wow!
tw
Got a question for ya. Do you get any rubbing with the 15mm up front?
Old Feb 10, 2008 | 02:19 PM
DNugget991GT3's Avatar
i was thinking of putting 3mm spacers on the front of my wheels
will i have any handling issues ?
i was told putting spacers on porsche is a bad idea.. esp considering that my car has some negative camber and i have i-forged wheels..
am i safe ?
Old Feb 10, 2008 | 03:48 PM
hollywood996tts's Avatar
hollywood996tts has a spectacular aura abouthollywood996tts has a spectacular aura abouthollywood996tts has a spectacular aura about
And remember, when adding spacers always check the lug-torque after a short drive, the longer wheel bolts may stretch, thereby lossing pre-load. It will sund like your wheel bearing are going bad....don't ask me how I know
Car looks great Zuma! Are you going to have to roll your rear fenders when you drop?
Old Feb 10, 2008 | 04:18 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
Looks tough, how wide is your back wheel and what size tire are you running back there?
Old Feb 10, 2008 | 04:35 PM
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
Tom,
Your car is so perfect I hate you!
Old Feb 10, 2008 | 06:36 PM
Zuma 911's Avatar
Heres a few answers.....
Yup, and probably a little more negative chamber too.
I'm running 20" x 11" Victors with Vredestien 295's
It's comment's like this that make the countless hours of maintenance and detailing worth it. Thank you very much!!
Old Feb 10, 2008 | 07:57 PM
TT Tommy's Avatar
No rubbing. Stock tires and wheels. Car looks amazing with this setup.
tw
Old Feb 10, 2008 | 09:47 PM
Turbo Fanatic's Avatar
Stock wheels can run 15mm front and rear, even if lowered. You can run even bigger in the rear if you roll the fenders (very easy with a 3lb mallet with the striking end covered in a few layers of masking tape).
you need longer wheel bolts if you get spacers. Stock are 45mm + add for spacer size. I found that 60mm bolts work with 7 and 15mm spacers.
I have become the biggest fan of spacers since the putting them on my TT. Even run 25mm spacers all around on my Acura TL.
Old Feb 11, 2008 | 01:58 AM
deandob's Avatar
deandob is infamous around these parts
Does adding spacers affect the handling?
Old Feb 11, 2008 | 08:07 AM
glowone's Avatar
glowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to behold
spacers
I have never seen so many people add spacers as Porsche car owners.
Spacers may make your car look better but I think there is a ligitimate argument that spacers are not good for performance driving.
I was always told to get correct offsets and to never use spacers.
Most custom wheel manufacturers can make any offset you want. Why not just get the offset another +7 or +15?
If your car takes a +40 offset in the front why not just order wheels with a +33 instead of adding a 7mm spacer?
ZUMA : Your car looks great. I am sure you are proud to own such a beautiful example of a Porsche Turbo.
