Thinking about LSD
Old Mar 8, 2008 | 10:00 PM
Zippy's Avatar
Thinking about LSD
I'm thinking about getting a Guard LSD http://www.guardtransmission.com/velocity.htm
Sounds like there are a lot of benefits provided buy a LSD. Better acceleration out of corners, ability to break later going into corners, better straight line acceleration for bigger HP cars. On the downside, an LSD can induce under steer. There are various 'ratios' available for lockup during acceleration and deceleration. I'm very confused as to what is the best set up for me. I will be tracking the car very infrequently as the closest track requires a weekend trip. I have a young family have put most of this on the back burner for a few years. I plan on getting out to the local drag strip a few times this summer, but don't want a car that will plow through the corners. My car is a summer daily driver. I will most likely be upgrading power a bit beyond the basic GT700 kit in the near future. Also considering stretching out the lower gears. What happens with LSD / PSM combo?
All input would be much appreciated.
Mike
Old Mar 8, 2008 | 11:25 PM
sechsgang's Avatar
sechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant future
honestly, i would just go gears. The LSD just seems like it doesnt fit the way it should (dynamically)...I guess thats what the GT2 is for...haha...some may say otherwise, but just my .02
Old Mar 9, 2008 | 06:50 AM
silvershark's Avatar
silvershark is infamous around these parts
Thumbs up Lsd
One of the best mechanical mods I have done.
Rarely does the PSM engage now. (if tires are at temp)
With the Guards LSD you are no longer so dependent on anti-lock
brakes w/PSM for your traction control.
I was advised not to use the tightest lock up unless using slicks.
With the LSD you have the best of both worlds...
GT2 w/PSM & AWD...
I love mine and would recommend to all > 600HP or frequent tracking.
There are those who want to comment...poo-poo the need,
but unless you have it, or driven one to compare... you don't know.
Good luck on your decision, let us know if you make the plunge.
PM me if you would like to discuss further.
Old Mar 9, 2008 | 07:17 AM
SMR's Avatar
SMR
SMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the rough
LSD is a must for active drive people
Old Mar 9, 2008 | 10:43 AM
Zippy's Avatar
Thanks for the responses guys. What is the correct ratio? I was thinking 40% (Braking) % 60% (acceleration). Silvershark, what exactly are you using?
Mike
Old Mar 9, 2008 | 11:41 AM
Pierre996TT's Avatar
Pierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura about
Silvershark, how much? interesting
Old Mar 9, 2008 | 11:55 AM
Triss's Avatar
Triss is infamous around these parts
The title of this thread implied it had nothing to do with Porsches...
But as far as LSD for cars, it is a must-have..
Old Mar 9, 2008 | 12:34 PM
Dr_jitsu's Avatar
LSD is bad MMMMKAY!
Old Mar 9, 2008 | 08:04 PM
Mike
40/60 is what was recommended to me. That is what I went with.
Old Mar 10, 2008 | 05:27 AM
Lsd
$2500 plus labor... +3hrs with clutch job.
Old Mar 10, 2008 | 04:13 PM
Zippy's Avatar
Originally Posted by Dr_jitsu
LSD is bad MMMMKAY!
No micro-dot here! We're talking cars!
Old Mar 10, 2008 | 05:03 PM
Kaizu's Avatar
Kaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud of
Just got a 40/65 LSD installed to a 4wd Turbo. Manthey-Racing themselves suggested it as a worthwhile upgrade.
The track season starts in a month so I will let you know...should be really great acceleration from the corners and also lower stress on the Visco-clutch for the front wheel drive!
(But without active track driving not sure would I opt for it...)
Old Mar 10, 2008 | 06:40 PM
Zippy's Avatar
Looking forward to hearing your comments. It's supposed to make a significant difference to the character of the car (which is kinda scary). Are they using a Guard? Perhaps something different in Europe. Did they give you some options for ratios? Any comments on why 40/65 was chosen/recommended?
Thanks!
Old Aug 4, 2009 | 10:58 PM
kwerks's Avatar
kwerks has a spectacular aura aboutkwerks has a spectacular aura aboutkwerks has a spectacular aura about
updates?
Old Aug 5, 2009 | 08:29 AM
GBXSport's Avatar
GBXSport has a spectacular aura aboutGBXSport has a spectacular aura about
there are 2 diffs on this car, right? (b/c of awd) If so, do you only get an lsd for the rear? How does this affect the AWD system?
