Lower control arm
Old Apr 26, 2008 | 07:22 AM
sandvik996tt's Avatar
sandvik996tt is infamous around these parts
Lower control arm
Is this the same part in front and back, L/R ?
Old Apr 26, 2008 | 09:43 AM
triple_nickel's Avatar
triple_nickel is infamous around these parts
Suggest you take a look at
https://techinfo.porsche.com/techinf...SA_KATALOG.pdf
Note: US model info
Front to rear are different. Left to right depends on which arm is used.
Old Apr 26, 2008 | 10:58 AM
Look at this site ; http://dcauto.gotdns.com/illustration/index/816202129
Part 996 341 053 07 same as front an back !
But not here : https://techinfo.porsche.com/techinf...e=MainFrameSet
Rear have a part no ....14 instead of .....07 ??
Old Apr 26, 2008 | 11:51 AM
Looks like in 04 they changed to be the same. 03 and earlier are different. Look at the 'remarks' column for model year applicability.
Old Apr 28, 2008 | 02:50 AM
They are the same front and back . New no. is .... 16
Is there any sitesponsor that is selling controll arms ?
Old Apr 28, 2008 | 11:14 AM
SuncoastSteve's Avatar
SuncoastSteve is a splendid one to beholdSuncoastSteve is a splendid one to beholdSuncoastSteve is a splendid one to beholdSuncoastSteve is a splendid one to beholdSuncoastSteve is a splendid one to beholdSuncoastSteve is a splendid one to beholdSuncoastSteve is a splendid one to behold
The front and rear are the same. For all years 996T, the part number ends in "16". You can ignore the "07" and "14" numbers, because they both supercede to the new "16" number.
It looks like we have one in stock, and they're easy to get fast.
Old Apr 28, 2008 | 01:17 PM
melsta's Avatar
melsta has a spectacular aura aboutmelsta has a spectacular aura aboutmelsta has a spectacular aura about
how much does the 996 gt2/gt3 control arms cost?
Old Apr 28, 2008 | 01:56 PM
The GT(x) arms are a little more complicated because they are a multi piece adjustable control arm (the fronts anyway, the rears are the same as the all the other 996's and 986's). For the arm, flange, and hardware, you're looking at about $275 per arm then whatever adjusting shims you would need.
Old May 22, 2008 | 11:01 AM
PV=nRT.
Sep 9, 2022 06:06 PM
Rockinc1
Sep 30, 2015 06:44 PM
