Oil Change?
Old May 12, 2008 | 09:32 AM
Conaswr's Avatar
Conaswr is infamous around these parts
Oil Change?
A question for all of you guys with modded cars, how frequent do you change your oil? Also what brand/weight is your preference. I have been told with synthetic you do not have do it often <3000mi.
Old May 12, 2008 | 10:23 AM
cfi_luz's Avatar
cfi_luz is infamous around these parts
I change mine every 4-5,000 unless I attend a track day, then I change right afterwards. I have been using 5-40 synthetic.
Old May 12, 2008 | 01:30 PM
Mikelly's Avatar
I'm dumping mine every other track event, along with the tranny fluid. I'll average about 1500 miles at the most between changes... I'm also using Mobil1 Synthetic Turbo Diesel Truck 5W40 or Shell Synthetic Turbo Diesel Truck 5W40, whichever is available at the time.
Mike
Old May 12, 2008 | 04:14 PM
996twin_sc's Avatar
996twin_sc is infamous around these parts
every 3k
Old May 13, 2008 | 07:54 AM
Conaswr's Avatar
I try to do it every 3k or so, but always in the beginning of the spring after it been sitting. I have been enjoying the car so much because of our crappy winter, I am putting a lot more miles on the car.
Old May 13, 2008 | 09:04 AM
chinaleeexports's Avatar
chinaleeexports is infamous around these partschinaleeexports is infamous around these parts
I have been doing 3,000 or every year which ever comes first. Factory Mobil 1.
Old May 13, 2008 | 09:13 AM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
I noticed that there are two kinds of Mobil1 Synthetic 5W40, one for Turbo Diesel Truck and one for European cars. Are they the same? I guess I can use them both according to Mikelly; is that a correct assumption? If yes, can you mix them?
Thanks.
Old May 13, 2008 | 09:43 AM
996Choy's Avatar
996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of
Summers here can get to over 100F, and I push my car very hard. Should I consider something like 5W40?
Old May 13, 2008 | 10:09 AM
wross996TT's Avatar
might even go 5W50.
Old May 13, 2008 | 11:37 AM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
I'm about to head off to Spa and Nurburgring for a week of serious action on track, I have moved from 5-40 up to 15-50 just for summer tracking, then move back down to 5-40 for the rest of the year.
Old May 13, 2008 | 04:34 PM
WyattTT's Avatar
WyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud of
For those of you that are changing your oil very frequently, are you also changing the filters?
Old May 13, 2008 | 05:03 PM
it's a must, no point in changing oil if you don't do the filter.
Old May 13, 2008 | 05:37 PM
Mikelly's Avatar
Guys I'm not the oil guru, but I'm following the advice given by Kevin at UMW...
I've switched over due to reasons provided on his website.
Mike
Old May 13, 2008 | 05:53 PM
smokinxtreme's Avatar
smokinxtreme has a spectacular aura aboutsmokinxtreme has a spectacular aura about
Hey Guys Can You Use Mobil1 0w40........
Old May 13, 2008 | 06:00 PM
schred's Avatar
schred is infamous around these parts
Maybe I had better read my manual again, as I thought 0w 40 was the reccomended viscosity from Porsche ? And yes, change the filter, it is cheap and why leave a dirty filter in. Dont forget to drain the oil from the turbos as well .
