Want to run Toyo R888, negative camber question.
Old Jun 26, 2008 | 12:18 AM
dus10r's Avatar
Awaiting Email Confirmation
dus10r is infamous around these parts
Toyo recommends at least -2.5 deg of neg. camber for the R888's. How much neg. camber can be dialed into the stock suspension?
Old Jun 26, 2008 | 12:20 AM
Turbo Fanatic's Avatar
That's a bit of camber. Running that on the street?
Old Jun 26, 2008 | 07:45 AM
BigBadBen's Avatar
BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !
I run - 1.4 front and rear on my RA1's. Running -2.5 on the street and the car will be very darty at higher speeds. You will also wear them out in no time flat.
I assume we are talking street driving here?
Old Jun 26, 2008 | 09:57 AM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
I run 3.0 and 2.5 on track and on the street. It isn't darty on track at high speed, why would it be that way on the street?
Old Jun 26, 2008 | 10:10 AM
BigBadBen's Avatar
Al,
Tramlining...it is a major issue here in the sticks with crappy roads, heavy trucks and logging trucks. My car wonders all over the place, the more neg camber the worse it is.
By default higher deg camber numbers means much better turn in but twitcher high speed straight line stuff with more correction...No?
Always has been for me setup plus major inside tire wear.
Old Jun 26, 2008 | 11:38 AM
tom kerr's Avatar
need to know what your intended use is. the R compound tires are really a track tire that you can drive with if you need to.
much better selections for a street car.
all R compound tires like or require more neg camber than a stock suspension will allow.
you may get 1.2 -1.5 on stock if lucky
Old Jun 26, 2008 | 11:39 AM
tom kerr's Avatar
Originally Posted by BigBadBen
Al,
I think that the wider the tire the more tramlining you get as well?
Old Jun 26, 2008 | 11:40 AM
Al Norton's Avatar
Guess I wasn't thinking about rough and uneven roads. My car would probably be terrible on those. I don't notice any twitchiness in straignt line on course but all the tracks are pretty smooth.
Old Jun 26, 2008 | 11:43 AM
BigBadBen's Avatar
Sure that as well Tom. On a recent P-car road trip/meet I went on the RA1's were spectacular, a lot better that my previous MPS2's by a long shot. They stick like glue!
Rguy
Apr 12, 2020 11:11 PM
Feelgood MD
Mar 24, 2016 09:35 AM
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
HotRod
Sep 10, 2015 07:17 PM
PelicanParts.com
Sep 2, 2015 02:15 PM
