profile for 19 x 11 rim
can i run a higher profile on my 19 inch rim for a 996 turbo. currently running a 315/25/19 and would like a bit more sidewall. Could I do a 305/30/19?? Anybody doing this? any pics would be appreciated. TIA I think the front is 235/30/19
Bad idea to use 305/30 19 rear tire. The diameter difference is great enough to cause your front differential to overheat. There is no sensor in the front differential and you learn of a problem is by front diff failure.
Could I adjust the front tire as mentioned to avoid the diff problem?
hey boca996tt, can you post the exact tire size/brand you were running. Also do you happen to have any pics of that setup. I think a bit higher profile looks good like the 997 gt2 has in the rear.
It was continental sport contact 2 size 235/35-19 & in rear I had 295/30-19.. rear tires were stretched a bit to fit my 11.5 rim
Well, I have bent one rim w/ regualr city driving. I just like the higher profile look, feel i have more "cushion" with a higher profile. Lastly, more availability and cheaper to buy tires that are 295/30 or 305/30. Not a huge deal, but if I could safely run the 305/30 with 235/35 up front I would do it.
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
