Who here wrenches 100% on their car?
I've been looking at a lot of threads and it seems like there's a lot of DIY'ers on here, which is great as I barely trust anyone but myself with my cars.
My main question is, has anyone successfully worked on their engine, without a lift? Is it even remotelly possible to remove the drivetrain without a lift(I noticed my cherrypicker will be useless)? Or do I need to look for a new house with a garage big enough to host a lift?
engine will need to be dropped, not lifted, as you've stated. to do so, i think you'll need a lift to raise the car high enough. obviously, you'll need engine hoist/jack to raise/lower the engine from under the car.
You might need a new neck if you do manage to drop the engine and work on it without a lift.
OK. So a comment.
I suspect you can count on ONE HAND the number of people here who wrench "100%". Why?
Read this: http://www.imagineauto.com/996TTbuild.htm
Once you recognize what is required- only tooling- you realize there aren't many folks with that calling. Indeed, fewer when you subtract those 'in the business'.
I'd say even if you do 50%, you need to find a 12'1" garage ceiling, and drop in a lift!
A
A
Now that my lift is working again, I'm doing as much as possible myself... Why? I will know if I scratched it. I will know if a job is done properly. I will know that my car isn't in a crowded lot getting bumped, getting abused by some service lackey or tech.
If something MAJOR lets go, I'll use my aftermarket warranty. Until then, I'll continue doing my own stuff...
Mike
Mike
You mean something like this?
Mike
Mike
OK. So a comment.
A
A
Mike
Mike
When you look at that engine build, you have no choice but to be a bit humbled. At least I do. THAT is "100% of your wrenching"!
A
Well here's what I know I would do...
I would remove my motor
I would remove my transaxle
I would remove my front axle/diff
I would remove all suspension components
I would remove my own brake system components
I would remove any body panel required on this car
I will do my own alignments starting this week
I would NOT rebuild one of these motors myself. I expect that there are many tips of the trade that are hidden in these motors that can make or break a proper build. I'd "consider" rebuilding my own trans, depending on the information and support my tuner and local indy could provide.
Modified Cases
GT3RSR Oil Pump
New Bearings
Seals
Carillo Rods
New Pistons/ Rings/ 3.6 Cylinder liner
Upgraded Head Gaskets
Studs
Your choice of porting - stock/ stage 1 / stage 2
All based around a core exchange.?
Sweet.... Dream Car garage.
I do 20% of the work at my house (Battery, DV's, Wastegate alterations, custom flash programming, wash, wax, air filter).
Not at this time. My motor seems to be running well without issues. It's got 19K on the clock and its motor mod days are over. I won't be upgrading beyond the power it currently has, so I "should" be OK.
Mike
Mike
Would you be interested in purchasing a built short block consisting of:
Modified Cases
GT3RSR Oil Pump
New Bearings
Seals
Carillo Rods
Studs
Modified Cases
GT3RSR Oil Pump
New Bearings
Seals
Carillo Rods
Studs
I'm with Mike. I'll pretty much handle anything with the exception of cracking the motor or cracking the code...
The "biggest" thing I have had to do is a new clutch, slave, etc..yeah whatta *****...and don't even ask but I put the ring gear in BACKWARDS so I have done TWO clutches! I have done a 24/18 conversion solo but that wasn't difficult. Something like that most people can do in their garage. Tranny and/or clutch stuff...., lift, tranny jack, etc are all but required....
I just don't trust the dealer to fix something better than I can, given their philosophy of simply throwing parts at a problem until they fix it. To me, that is nothing more than throwing money at the problem. My money.
I only wish I had someone like IA around here!
I'll try to get some shots of the shop and lifts posted....I think you guys will like them...
BlackMarketRacing
12-03-2015 10:46 AM
PorscheEnthusiast
11-13-2015 02:23 PM
