Stereo Upgrade for MOST System
Old Sep 7, 2022 | 03:59 PM
  #31
'02996ttx50's Avatar
I recently added an apple car play setup and should have done long ago. but everything worked until it didn't as my sub was failing.
now I have great features and paired with I-phone but need a separate amp to run the sub and didn't want to spend a grand +/- on just the amp and add'l labor.
I miss having bass frequencies and now my "all tweeter" system sounds like ***t.
Old Sep 7, 2022 | 08:52 PM
  #32
G8rJimbo's Avatar
G8rJimbo is infamous around these parts
Originally Posted by Stebo
I'm still on... but when i switched back to apple from android, I can't find the damn forum in the app store, so I'm around A LOT less. Anyway, I made a custom mount using a piece of plywood that I covered in carpet. then, I bent some metal ( i think it was a galvanized simpson strap from home depot), drilled out the mounting holes, painted it black, and used the factory bolt and one of the attachment points for the CD changer on the fire wall. Unfortunately, my car is in storage at a buddy's house otherwise I'd run out there and take some more pics.
If you look close in the pic above you can see what i'm talking about. But yeah, totally custom. I got the carpet from a local car audio shop - thinking back on it - I had them use their spray glue and carpet to wrap it for me. It came out great. The carpet matches so well, that it is impossible to tell. I screwed the amp to the plywood and then bolted the plywood to the firewall.
It just sits there and is held in by the one bolt that you can see. It's totally secure and I drive like a maniac.
Good to know!
Which amp is that in your install?
Old Oct 10, 2022 | 10:35 PM
  #33
awdmig's Avatar
awdmig is a name known to allawdmig is a name known to allawdmig is a name known to allawdmig is a name known to allawdmig is a name known to allawdmig is a name known to all
So how did you have the stereo hooked up? With a Most converter? It retained the factory Bose amp?
Originally Posted by G8rJimbo
Good to know!
I'm running a kenwood amp mounted it to the Cd changer bracket.
Old Oct 13, 2022 | 04:17 PM
  #34
im sorry but I don't actually remember since not only did I not do the installation but had to go to an indy car stereo place after Best Buy messed it all up.
whatever they did, it works but I need a separate amp now ( a 5 channel? ) to run the sub which is currently dead weight.
I should have paid closer attention because I do recall pulling the old amp out. but if I bought a "new" amp it was not sufficient to handle the 6 speakers PLUS the sub.
I think thats how I left it. "working" but without the sub = bass. in other words, I wasn't spending another grand post "Kenwood apple car play unit" plus installation.
ktownlilrye
Jul 1, 2014 09:27 AM
softail
Dec 2, 2010 12:44 PM
scott_fx
Cayenne 955/957
18
Aug 12, 2009 01:33 PM
Baasha
Oct 21, 2008 10:50 AM
dwaynemosley
Apr 12, 2004 02:34 PM
