Diverter's
Old Aug 2, 2008 | 08:39 AM
bavboym3's Avatar
bavboym3 is infamous around these parts
Diverter's
When the DV's go bad do they sound like a BOV? I drove to work this morning an when I was boosting I could hear air coming out. I never heard this before. I have DV's coming next week.. I just want to make sure that my prob.
Old Aug 2, 2008 | 09:38 AM
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
BAV: Although I've never heard one because I changed out my platic diferters long before the diaphram in the OEM ones failed....I'm told they sound like a "honking noise"....so you could very well be hearing the result of a failed DV.
Old Aug 2, 2008 | 09:47 AM
halluz's Avatar
halluz is infamous around these parts
I've been told it sounds like geese honking coming from the engine bay.
Also I've read and been told to make sure you keep boost low once you hear the honking to keep from sending the diaphragm of the bad DV in to your turbo.
Old Aug 2, 2008 | 10:51 AM
bavboym3's Avatar
I have heard the "honking noise" comments before too. Allthough I am not hearing them. I can just hear the "boost" almost like its spilling out, but I am still getting one bar solid. I will replace them, and go from there.
Old Aug 2, 2008 | 01:35 PM
wross996TT's Avatar
Might I suggest first telling us what MY and mods you have, please. Then get the codes read JIC. There are many things it could be from DVs to leaks...
Old Aug 2, 2008 | 02:41 PM
maxwell's Avatar
maxwell is a jewel in the roughmaxwell is a jewel in the roughmaxwell is a jewel in the rough
Still waiting for these to go. 33k miles/7 years and no failure. If they don't break...I don't replace.
Old Aug 2, 2008 | 05:41 PM
Adam Bowles's Avatar
Adam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud of
Do you have an intake? My v-flow makes the diverters more audible. When I'm shifting I hear a psssst from the diverters, and I have upgraded diverters.
Old Aug 2, 2008 | 06:38 PM
Max: I have a perfectly good new set of the plastic ones that I'd be willing to give you in case yours finally give out....
Adam: Are you parked near any bushes in a park when you hear the Psssst?
Old Aug 2, 2008 | 07:32 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
the pssss sound should be there when i changed to a larger air floe sys i lost the psss sound i really need to know why
Old Aug 4, 2008 | 06:54 AM
bavboym3's Avatar
I have FVD software, and a bmc filter.
I didnt get the codes read yet. I will get them a little later today
Old Aug 13, 2008 | 08:16 AM
bavboym3's Avatar
These are my codes... Anyone know what is wrong with her?
P1250
P0491
P0492
Old Aug 13, 2008 | 11:11 AM
wross996TT's Avatar
P1250 Boost Pressure Control Deviation - Above Limit
Possible fault cause
♦ Bypass flaps incorrectly adjusted
♦ Turbocharger faulty
My guess DVs.
P0491 Secondary Air Injection System, Bank 1 – Below Limit
♦ Secondary air injection pump is not triggered
♦ Secondary air injection pump does not work
♦ Air supply lines restricted
♦ Electric change-over valve does not function
♦ Air change-over valve does not function
♦ Vacuum system leaking
Check for leaks, most likely a leaking DV or hose connection
White991TT
Mar 8, 2016 06:01 AM
sdg1871
Nov 22, 2015 07:27 PM
flewis763
Oct 4, 2015 04:14 PM
Bmanny
Sep 16, 2015 08:29 AM
