passenger side window possessed?
Old Aug 4, 2008 | 09:46 PM
mtesh73's Avatar
mtesh73 is infamous around these parts
i tried the search and got something similar but not exact. i was hoping someone else has seen this problem. upon turning off the car and going to the passenger side to get some folders off the seat, opened the passenger door and the window goes down automatically. this happened a few times in the past and i thought nothing about, (must be a convenience feature???) so i return to the drivers side, put the passenger window up and go back to the passenger side to get my folders, open the door and the window goes down all the way again. damn it, sob, and some other choice expletives go flying. i checked the owners manual, nothing there to disable a convenience feature like this so i am guessing it must be a malfunction of some sort. the car runs perfectly otherwise, no problem starting after 3-4 days of sitting, no other wierd electrical issues. any input would be appreciated.
Old Aug 4, 2008 | 09:50 PM
Tboy911's Avatar
Tboy911 is infamous around these parts
Had a similar problem but not exactly the same.
Replacing the power window regulator fixed it.
Old Aug 4, 2008 | 09:51 PM
mtesh73's Avatar
oh yeah, car is CPO'ed, think it will be covered under warranty?
Old Aug 4, 2008 | 11:07 PM
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
Check the little booklet that came with your car...it's the CPO booklet in your leather owners manual folder...that should tell you what's covered....almost everythign that's gone wrong with my car under CPO was a "wear item" and not covered.
Old Aug 5, 2008 | 06:44 AM
pumalex's Avatar
pumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond repute
that looks like a defective sensor, probably the one for the door handle.
Old Aug 5, 2008 | 08:35 AM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
Did you have one of those RemoteTops installed and turned on the chirp function?
Old Aug 5, 2008 | 08:50 AM
wachuko's Avatar
wachuko is infamous around these parts
Window regulator, not cover under CPO... A friend (jimq at rennlist) recently had that replaced in his car...
Old Aug 5, 2008 | 03:05 PM
roadsterdoc's Avatar
Member
roadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to behold
I had similar symptoms which resolved after replacing a weak battery and faulty ignition switch.
Old Aug 5, 2008 | 03:11 PM
heavychevy's Avatar
Not laughing at the situation, but your explanation and reaction is classic, I was laughing when I read the topic.
Old Aug 5, 2008 | 09:23 PM
mtesh73's Avatar
it was pretty frustrating>>>>
and pretty funny nontheless, good thing my wife didnt see it. i would never hear the end of it.........."you look like the dog circling her bed before she lays down" in a high pitched kinda tone!!!!!
interesting idea with the weak battery, i have no other symptoms of a weak battery, but i also noticed that my ignition switch can be "notchy" sometimes as i am withdrawing the key. the car is at the dealer now, we'll see what they come up with.
thanks for the input, guys.
Old Aug 5, 2008 | 09:25 PM
mtesh73's Avatar
is there such a sensor???>>>
i am guessing it would be inside the door handle mechanism somewhere. any pointers on where it would be. i will also tell the dealer to take a look at this sensor too.
Old Aug 5, 2008 | 10:34 PM
pumalex's Avatar
i beleive you can see it when you open the dor from the inside behind the handle.
Old Jan 18, 2009 | 10:47 AM
4G64T's Avatar
4G64T is infamous around these parts
My car also does the same thing. It does it either when I open the door from the outside or from the inside.
Old Jan 18, 2009 | 02:20 PM
jpflip's Avatar
Did you try this... After replacing a window you have to do this step : Standardising the new power window motor
1. Switch on ignition.
2. Open door window completely by continuously actuating the power window operating button,
and then close window. Press power window button until the window is closed and is switched off
by the blockage detection function of the power window motor. Standardisation is then
completed.
Old Jan 19, 2009 | 08:34 AM
4G64T's Avatar
I haven't replaced anything yet. What should I look at replacing - power window regulator?
