Pagid Yellows
#32
Thanks, Scott
#33
Your GT2 has the tamest pads available.
1/2 wide flat section (though I rounded mine) especially on the edge where the disc enters the caliper.
Jury is out wheter the other edge does anything, seemed to on mine.
Roughly THIS concept:
#34
wow that's an excessive bevel. I have just used my die grinder and carefully taken the LEADING edge only to about an 1/8" is all you need. 1/2" bevel on both ends would be loosing 25% or more surface area!
I use the Pagid 4-2-1 black pads for the street and they are much better than the P90 yellows that are oem on the GT2/3. No noise and good bite. Better all around pad. For the track the Pagid Yellow 29 w/ the black 4-2-1 seems to reduce the front bias.
#38
Craig at www.Rennstore.com told me to bevel the leading and trailing edges at a 45 to reduce noise...now ZERO noise and I leave them on full time, street & track.
#40
I'm going to have to learn how to do that. I've already noticed that it's intermittent depending on how hard I am on the pedal.
#42
http://www.pagid-brake-pads.co.uk/products/index.php
Jon
Mico
09-26-2015 03:04 AM
bongnation
09-25-2015 02:58 PM
