Front camber issue... Resolved!
Old Oct 10, 2008 | 03:29 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
I posted a while back about putting GT3 lower control arms on my car with the hope of getting to high negative camber. I had a problem of rubbing in the front of the wheel wells where the side radiators are.
My indy resolved the problem by removing the wheel well plastic cover and relocating the radiators forward about an inch. This was described in another post that people referred me to. This took care of the problem, and I am now at -2.5 degrees on the front, and looking forward to trying this setup on track in a couple of weeks.
Jon
Old Oct 10, 2008 | 03:52 PM
oak's Avatar
oak
I think you need to check your caster.
Old Oct 10, 2008 | 04:02 PM
FAST FWD's Avatar
Oak -
Forgot to mention that he did that too. Ended up pressing out and rotating the bushing in the control arm. That helped, but wasn't enough to resolve the issue.
Thanks.
Jon
Old Oct 10, 2008 | 04:36 PM
oak's Avatar
oak
you need to replace the bushing with a GT version or the solid type. this of course if you want an ideal caster.
Old Oct 10, 2008 | 04:43 PM
oak's Avatar
oak
jon, I think I have a set of GT ones with rubber insulation. if you need a set. are you on solid type? or are you running stock turbo?
what size and offset wheels are you on?
Old Oct 10, 2008 | 04:57 PM
FAST FWD's Avatar
It's the GT3 bushing with rubber insulation that came with the GT3 control arm. There is some compliance there, but there is also compliance at the pivot for the caster control as well. I didn't think that the extra $500+ for the solid bushing was worth the expense, at least for the moment.
I have a set of stock turbo wheels with Hoosiers, another with MPSCs, and another set of Champion wheels with Kumhos for the street. They all rubbed about the same before, but not anymore. All are stock sizes 225/40-18.
Thanks,
Jon
Old Oct 10, 2008 | 07:10 PM
Mikelly's Avatar
Jon, Oak is right, and I'm really gonna eat crow here...
Went to an INDY shop while they were "clocking" a guy's thrust bushings. Those solid adjustable bushings that are sold by some of the vendors will do the trick, in conjunction with rotating the upper strut mounts.
I watched them set a guy's GT3 up with 3 degress negative camber and about 6 degrees caster in no time... I was actually pretty amazed...
Damn, I'm done questioning Oak when he tells me something!
Mike
Old Oct 10, 2008 | 07:54 PM
oak's Avatar
oak
LOL, if I can save you the agony of going through what I have, check out this bugger job. by one of the best shops in so cal. been there done that.
jon, you see the solid bushing and where the holes are indexed they are spaced out in comparo to the GT version.
Enemy
Nov 10, 2015 08:01 AM
33jacket
Aug 31, 2015 09:06 AM
The Oss
Aug 24, 2015 08:19 PM
TrackOne
Aug 20, 2015 12:56 PM
