Battery Dead Trunk won't open
Old Oct 18, 2008 | 10:41 AM
rwilliamtaylor's Avatar
rwilliamtaylor is a glorious beacon of lightrwilliamtaylor is a glorious beacon of lightrwilliamtaylor is a glorious beacon of lightrwilliamtaylor is a glorious beacon of lightrwilliamtaylor is a glorious beacon of light
My battery is dead and when I try to use the emergency trunk release in the fuse panel the alarm goes off but the trunk won't open.
Any ideas?
Old Oct 18, 2008 | 10:47 AM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
Have you tried using the key to turn the alarm off, then pop the trunk?
Old Oct 18, 2008 | 10:49 AM
RickEager's Avatar
RickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond repute
Open your drivers door and look down under the dash for your fuse box. Near the center is a terminal to pull out toward you. Pull it out and connect a Positive side jumper or battery charger cable to it. Next hook a ground to you door striker for a ground. Hit the button and the lid should release. I had this happen to me when I left my lights on in the parking lot - Cheers!!!
Old Oct 18, 2008 | 10:51 AM
RickEager's Avatar
Sometimes you have to turn the key 2 times very quickly!!!
Old Oct 18, 2008 | 10:53 AM
The battery is too dead fpr the key to turn the alarm off.
I tried the fuse box terminal... that's what sets off the alarm.
When you turn the key twice... are you talking about in the ignition or in the door lock?
Old Oct 18, 2008 | 10:55 AM
RickEager's Avatar
Drivers door!!!
Old Oct 18, 2008 | 11:00 AM
RickEager's Avatar
Did you get it???
Old Oct 18, 2008 | 12:17 PM
996TTSCAB's Avatar
996TTSCAB is infamous around these parts
It is a snap if you have a battery charger/jump starter. If you are having difficult time figuring out, you contact me and I can walk you through step by step over the phone.
Old Oct 18, 2008 | 02:58 PM
Speedy996tt's Avatar
Speedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud ofSpeedy996tt has much to be proud of
There is a manual way to go about this...there is a steel braided chord behind the passenger headlight, you have to remove the front part of the fender liner where it meets the sidemarker (I believe you have to remove the sidemarker as well). You will need a flash light, once you have located the chord give it a good tug and the trunk will open. The chord is way the hell in there so you will definitely have to reach to snag it, I am in san diego as well, if you need me to walk you through it PM me and I will give you my phone #. Hope this helps!
Old Oct 18, 2008 | 08:13 PM
Thanks guys,
I had to leave it for a while to do other things today. i found the release chord in the drivers door frame. I pulled it and it broke (damn). I suppose it runs along the inside of the fender so I might be able to get at it from the fenderwell as well. I'll try it again later tonight or tomorrow. I'll PM you for the walk through if I can't get it.
Bill.
Old Oct 18, 2008 | 09:11 PM
RickEager's Avatar
Cool! Give us a heads up!!!
Old Oct 18, 2008 | 09:42 PM
Success
Got it....
I hooked the battery charger to the post in the fuse box and let the alarm go off for about 30 seconds. I was then able to use the key remote to turn the alarm off. Once the alarm was disabled the door switch worked and the trunk opened.
Thanks for all your help.
Bill.
Old Oct 18, 2008 | 11:35 PM
Just out of curiosity are you sure what you pulled on was the release chord for the trunk (you said it broke).... I know on my 01 and my dad's 02 the release is behind the passenger headlight, you might want to check to make sure what you broke isnt something important. Glad that you got the problem solved nonetheless...
Old Oct 19, 2008 | 05:03 AM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Speedy, you really should not be posting on the forum about how to get into a Porsche. No offense but it's not wise!
Old Oct 19, 2008 | 01:21 PM
Stevo, do a search all the info I have provided is already on this site.
PV=nRT.
Sep 9, 2022 06:06 PM
Paintballzen
Oct 10, 2020 12:22 PM
Rguy
Apr 12, 2020 11:11 PM
shifter_
Sep 8, 2015 12:07 PM
holmesatx
Sep 2, 2015 11:32 AM
