Spark Plug Selection...
Old Oct 29, 2008 | 07:26 PM
Imolas54's Avatar
Imolas54 is infamous around these parts
I did the search but want the latest info -
If i was to upgrade my car w/ a ECU tune, 1.2 bars on k16 - what plugs would best fit that applications and what should the spark plug be gapped to?
TIA
Old Oct 29, 2008 | 11:57 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
I would go with Bosch, FR6 LDC or LDU at that level.
Old Oct 30, 2008 | 09:01 AM
D_Nyholm's Avatar
D_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant future
What is the difference between LDC and LDU and why would you chose one over the other? I am planning on changing my plugs this winter and would love this info (GT610, 1.2 bar)
Old Oct 30, 2008 | 10:08 AM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
Your WAY over spinnning at 1.2 Bar with K16's. Use the Bosch LDC.
Old Oct 30, 2008 | 11:36 AM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
I prefer these Denso Double Platinums (PK20PR-P8)
Denso Double Platinum Spark Plug Porsche 996TT
$42.95 / set
Old Oct 30, 2008 | 06:48 PM
Imolas54's Avatar
what do i need to gap those at?
Old Oct 30, 2008 | 06:49 PM
Imolas54's Avatar
what does that mean "over spinning"??
Old Oct 30, 2008 | 07:35 PM
art4iza's Avatar
FR6 LDU's are used in GT2's.
Old Oct 30, 2008 | 11:08 PM
sharkster's Avatar
Not sure about the 1.2bar part on K16s. I'd stick to 1bar or at most 1.1... Either way, the plugs you should use are the FR6Bosch. They'll last longer than anything else. For higher hp apps just go with the Densos.
Old Oct 31, 2008 | 01:39 AM
RickEager's Avatar
RickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond repute
Both plugs are good from what I've read. You can do a search here an also on Rennlist or Renntech
Old Oct 31, 2008 | 05:02 AM
Imolas54's Avatar
what should they be gapped at? thanks
Old Oct 31, 2008 | 05:59 AM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
I have the bosch fr6 ldc's and have had no issues. Come at the right gap I think from the get go.....
These don't have cold weather issues. Some plugs do. I don't know which ones. Call some engine builders that see snow/cold if you need more data like Stephen at IA or Kevin at UMW. You are in NYC.....Tx/Fl/Miss/etc. warm places may not need what you need.
Change them every 20k with a tuned car and go.
My plan. Doing it. No problems. Not worth thinking too hard as they are cheap and you don't get magical power from a plug despite the bs out there. Even if you did, can you actually "feel" 2 more HP.....it is funny when you sit and think about it. Having a detonation problem is just not worth it......
Most feel a stock k16 max's out efficiency at 1.0 bar to maybe 1.1....fyi.
No issues since the change, btw.
JB
Old Oct 31, 2008 | 07:46 AM
RickEager's Avatar
Plugs come pre-gapped. No worries on gapping them!
Old Oct 31, 2008 | 08:03 AM
onelove's Avatar
Correct, most of the time they come pre-gapped, it's always nice to double check them to make sure they didn't come out of spec during shipment. Most of the time they will be within specs but it's always nice to be sure.
Old Oct 31, 2008 | 11:25 AM
art4iza's Avatar
Absolutely agree with his statement.
Oct 6, 2015 06:13 PM
Oct 2, 2015 02:23 PM
UrsaMinor1
Sep 26, 2015 01:23 AM
WEEED
Cayenne
Sep 25, 2015 10:45 PM
jungt
Sep 16, 2015 05:28 AM
