Fuel Octane And Boost
Old Nov 12, 2008 | 11:58 AM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Question Fuel Octane And Boost
I'm in England and the best fuel I can get is 100 RON
What's the maximum boost I can run on this?
The reason I ask is I'm still deciding whether to go for 24/18g's or 24/20g's
If I can run sufficient boost I might be tempted to go for the 20g's
Old Nov 12, 2008 | 12:00 PM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
This is a question that you should ask your turner directly.
Old Nov 12, 2008 | 01:48 PM
Szpet's Avatar
Szpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud of
I had the same question and Todd at Protomotive gave me the answers.
Old Nov 12, 2008 | 02:06 PM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
I am with Tony on this one, ask your tuner whats the most you can get out of the car safely..key word is safely
Old Nov 12, 2008 | 02:11 PM
WOODTSTER's Avatar
And for us US folk, your 100 Ron is not as good as what we consider 100 Octane.
It is more like our 93 or 94 I believe. (please verify).
So depending on fueling you are probably in that 1.0 bar to 1.1 max type situation.
Good luck in talking to your tuner!
MK
Old Nov 12, 2008 | 03:33 PM
ant_8u's Avatar
I'm trying to find out how it compares to US fuel
I've found a website with it on - just doing the calculations
As for tuners - i will be using Todd
Old Nov 12, 2008 | 03:42 PM
Ist basically the same as our 93 octane... maybe 95 at most... with that said you will be limited to the same boost as most guys in the US....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Nov 12, 2008 | 03:54 PM
ant_8u's Avatar
Thanks Mark
May I say a personal thankyou to you for all your help so far - it is very much appreciated!
I've just worked out the following
98 RON = 91.5 AKI
100 RON = 94.5 AKI
With that in mind am I right in thinking I should stick with the 18g's?
Old Nov 12, 2008 | 04:00 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
hmmm...If 100octane european fuel is almost the same as 95 US fuel...then I do have a problem...I always get this fuel because it is the best available here...and my boost is 1,3 to 1,4...(k24/18g)Should I add some additives such as nos octane booster?
Old Nov 13, 2008 | 07:30 AM
ant_8u's Avatar
I think we should be 1.1-1.25 bar with this type of fuel?
If I run this level of boost could I go with 20g turbos?
Or should I stick with the 18g's?
Old Nov 13, 2008 | 07:56 AM
Tony@epl's Avatar
Ant-
Others may disagree with me...Stick with a 18g setup. You wont be disappointed.
I haven't seen positive results with the 20g's. I noticed no gains in power and significant gains in intake air temperatures. In my opinion the 20g compressor wheel is not a good match to the k24 housing.
Old Nov 13, 2008 | 08:04 AM
ant_8u's Avatar
Thanks Tony
I remember you saying previously about the increase in intake temperature
Old Nov 13, 2008 | 09:40 AM
i ve been running 1,35bar with k24/18g turbos and 100octane fuel without any issues...still stock ics but trying to install agency power...(it is difficult)
Old Nov 13, 2008 | 05:45 PM
ant_8u's Avatar
So,
If I go with the 24/18g's with 100RON (95 AKI) fuel I will be limited to approx 1.2 bar approx
As I am in England and the weather is always rubbish would I get any benefit from upgraded ICs - or would they be overkill?
Also - would I see any benefit from the proto intake and TB?
Should I consider these too or would they be wasted on my car?
Old Nov 13, 2008 | 06:26 PM
Adam Bowles's Avatar
Adam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud of
With the 18g's I only run 1.0 - 1.05 bar on 93 octane. I don't feel the need to run anymore boost with that fuel, and I just don't think it's safe. I know others here feel the same way, as does Todd at Protomotive. The car performs GREAT at 1 bar on pump gas, so I prefer to be as safe as possible with my $20K engine.
There has been more than 1 person who has done damage to their engine running too much boost on pump gas (1.3+ bar).
I will say that when running GOOD fuel, I'm much more liberal with the boost. I turn it up to 1.2 bar with 103 octane and it really screams. I know others here turn it up to 1.3 - 1.4 bar with good fuel and haven't had any problems.
