How to check the limited slip differential (LSD)?
Old Nov 28, 2008 | 11:30 PM
MotorsportsR's Avatar
MotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to behold
How do you check if a LSD on a 996 RWD is working properly? Wanted to know if my limited slip differential is ok. When both rear wheels are off the ground with transmission in neutral, wheels will turn the same way but if I turn one wheel really fast the other might not turn at the same speed. If transmission is in gear then wheels will turn the opposite direction. If I jack up one rear wheel with transmission in neutral, I can turn that one wheel easily but if it is in gear then I can't really turn it at all. Thanks for any info.
Old Nov 29, 2008 | 12:33 PM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
If a GT2 than I'd imagine a nice peelout on a level surface should tell you if it is working by looking at the burnout marks. If a 996tt than I don't think you have one from the factory if i'm not mistaken.
Old Nov 29, 2008 | 12:46 PM
Dr_jitsu's Avatar
Adam has peeled out the correct.
Old Nov 30, 2008 | 01:55 PM
Is there another way to check LSD other than a peelout? What if the driver side peel out mark is 6" longer than the passenger?
Old Nov 30, 2008 | 09:56 PM
adam699's Avatar
Make sure the surface is even and that the tires have even pressure. Your LSD might need a rebuild.
Old Nov 30, 2008 | 10:02 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
How is that new tune working? We gotta meet one of these days
Old Nov 30, 2008 | 11:54 PM
Yeah, we should meet. Aren't you going to Irwindale 1/8 track coming Thursday?
didn't check tire pressure, I will try to find a prefectly straight surface. It's limited slip and not no slip diffs so can burn out be perfectly even?
Old Dec 3, 2008 | 08:07 PM
Staff@RPM's Avatar
Staff@RPM is infamous around these parts
Hi. I had put only 1,500 miles on my motorsports lsd and needed to re shim it to get it working right. BTW it is rwd only. Tim
Old Dec 4, 2008 | 12:31 AM
This is on my 996 GT2. How did you know that your LSD need adjustment?
Jul 29, 2019 11:13 AM
Sep 14, 2015 06:42 PM
orbelo
Aug 30, 2015 12:26 PM
LiquidElephant
Aug 27, 2015 06:17 PM
