Recommendations on what to ask for in a PPI?
Old Dec 3, 2008 | 11:37 AM
Riz1's Avatar
Riz1 is infamous around these parts
Hey guys im looking to do a PPI as this car will be my first used car im about to buy so i'm new at this. What should i ask for when doing a PPI? Im **** with my cars so i'd like everything to be checked out. Should i get the PPI done at a dealership or an indy shop? thanks guys
btw the car is in Miami so any recommended guys/shops to do the PPI
Old Dec 3, 2008 | 01:52 PM
M32's Avatar
M32
M32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond repute
What's up bro? I think I've seen you on m3forum right? (AW m3?) Anyway, there's lot of threads about this but the short answer is the dealership's PPI is a standard two hour procedure. They plug up the car to the computer to get any codes and read any errors and they look also perform an exterior check (tires, brake pads, any visible paint work, etc).
I personally believe that to get an honest, objective opinion on the status of the car, you should either take it to a indy or a dealer that has neither sold or serviced the car.
Edwin
Old Dec 3, 2008 | 03:12 PM
s14roller's Avatar
s14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to behold
Edwin
Correct, a Porsche PPI is a checklist at the dealer that they follow. If the car is more modded, perhaps getting compression/leak-down done also.
Old Dec 3, 2008 | 03:14 PM
M32's Avatar
M32
I also agree. I've asked the dealers that I've had ppi's done before and they said "you don't need a compression test b/c if there was a leak, the computer would throw a code". Not sure if that's true but sounds reasonable?
Edwin
johnkent1212
NorCal
Sep 18, 2015 07:44 PM
Motams
Sep 15, 2015 08:59 AM
MrMiggy
Sep 14, 2015 02:18 PM
sparks
Sep 8, 2015 03:03 PM
