Who has the evo gt 700 pakcage?
GT700
I have it. Upgraded from Stage 4GTR. I also upgraded to stage3 clutch and lightweigt flywheel at the same time. I think the GT700 was need for some of the GTR kits as it addressed some fuel injection issues.
Re: GT700
i heard that the gt700 not only has the fuel injection upgrade, as well as a new set of turbo...
GT700
Yes, the GT700 uses the same turbos as the Stage4GT. The GT700 uses larger fuel injectors and upgraded fuel pump plus new programming. I noticed that the 700 does not pull the 1.4bar
that the GT and typically only goes to 1.2- 1.3bar max. This is probably a good thing. It definitely feels stronger and has no flat spot at 5k rpm. This is backed up by by the stronger and flatter dyno curves. I even swapped my EP Stage 2loud with the Fabspeeed SS after showing a significant power improvement in back to back dyno runs on the GT700 system. Although some have done it, I would not go beyond this level without upgrading my rods and associated hardware given what RUF and Chad have seen at these power levels. Note also that the GT700 requires 93 octane min. I was able to run 91oct. (I'm in Cal.) previously with my IBE switcher program.
Originally posted by luting_chen
oooopsi... =_=" then i got it wrong...
i guess i have gt700 then... hahahahahahaha
just did the fuel injection upgrade... ^^"
RC Injector versus Stock 996tt injector.
Craig,
I was answering your post and hit "edit" instead of "quote" by mistake. I tried to correct it and deleated it by accident.
You said Todd (EVO) doesn't use RC injectors any more. I replied.
Craig
So Craig, what are they using now? Unless I saw them I wouldn't believe it. They denied using them before. At the last shootout when Buddy was having problems blowing apart his intake, parts were removed and low and behold a red labeled RC Engineering injector materialized. It wasn't suppose to be there. hmmmmm.
I apologize for the screw up.
Craig
Stephen,
I'll believe it when I see it and I have one that I will be seeing in about a week. I'll announce what I find out then.
Actually, it isn't a real big deal. The 700 crank hp is about 630 rwhp. We were attaining that on stock injectors, although they were at their limits.
The larger injectors are definitely a plus.
The larger injectors are definitely a plus.Last edited by cjv; Sep 13, 2004 at 10:45 AM.
