Bumper Support Removal
Old Jan 2, 2009 | 05:45 PM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Originally Posted by MotorsportsR
A few pounds is not worth injury or your life! Please reserved these kind of talk for teens that got more ***** then brain (peace!!!). I would removed the carpeting in the car before I removed the bumpers! 19 lbs? Make sure washer fluid is empty and add 3 gallons less fuel every time you go to the pump. Problem solved!
I have to politely agree with this... The Alloy supports are as light as a feather anyway and the mounts are pretty heavy... they would add great protection as they are fairly strong. The main point here is safety and engine protection... the slightest bump on the rear end could be the cost of a motor or tranny. There was a recent motor that had the slightest of bumps and I can remember clearly that either engine/tranny housing was all smashed up.
Not nearly as bad as the guy recently that was running the cup car doors without any side roll bar protection whatsoever.
Old Jan 2, 2009 | 06:06 PM
tom kerr's Avatar
all my front and rear bumper stuff is off. see the below pics. those are low impact bumpers and are surely not going to save your life. the engine as you can see is completely behind the main frame. I dont recommend doing any of the bumper removals as I have done. My car is a track car and I am in the middle of a saftey cage. that being said removing anything from the rear of this car especially helps.
thats also why I have no mufflers and run straight pipes. we took a supports off and put on the cup car tow hooks that retract.
Old Jan 2, 2009 | 06:32 PM
MotorsportsR's Avatar
MotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to behold
+1 only removal safety feature if it is a track car with cage. On a track you probably will have a 5 point seat belts and a helmet. 10 lbs less in the rear is NOT going to help you that much getting on or off a single smooth banking 270 degree Fwy ramp.
Old Jan 2, 2009 | 07:14 PM
TXGold's Avatar
TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !
Tom, I thought I remembered you saying that you drive to and from events and a lot of the other time. I didn't think your car was just a track car??
Old Jan 2, 2009 | 07:26 PM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
Tom did you have your bumper supports removed prior to your GT2 front upgrade or did you do this mod while you where putting the new front on ?
Old Jan 2, 2009 | 11:53 PM
LamboTT's Avatar
LamboTT has a spectacular aura aboutLamboTT has a spectacular aura about
I really like the holes where the bumperettes use to be...is there a way for me to keep the bumper support and just remove those?
Old Jan 3, 2009 | 12:19 AM
Steve Theodore's Avatar
Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !
Heh...is there an echo in here?
Old Jan 3, 2009 | 01:29 AM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
Ok tvm for all the advice guys, in the end the aluminium cross member stayed on but I did remove the rear tow hood thread block and bolts, the exhaust heat shield and the metal strip by the engine catch. I guess in the US bumperettes alone are a worthwhile removal as they are not even required in Europe.
Old Jan 3, 2009 | 01:28 PM
Richard,
Did you mange to weigh all the related parts you removed from the rear of the car? Would love to know the total you achieved...thanks.
Old Jan 3, 2009 | 01:45 PM
TonyTurbo's Avatar
TonyTurbo is infamous around these parts
After removing stock bumper&supports and replacing them with carbon fiber bumpers is the only way to really save some weight!!!!
Old Jan 3, 2009 | 03:26 PM
tom kerr's Avatar
never said I didnt drive it on the street! drove it to work everyday this week and it is great. I do drive to close events and have someone take my Hoosiers down for me. so yes you can have the best of both worlds.
Old Jan 3, 2009 | 03:27 PM
tom kerr's Avatar
no used that opportunity to do it all at once.
Old Jan 13, 2009 | 07:41 AM
Prche951's Avatar
while on this subject, does anyone know if there are lightened bumper struts to replace the factory steel ones that connect the bumper to the body/frame? I thought that there was RSR struts or something like that made of aluminum.
Jul 29, 2019 11:13 AM
COBB Tuning
Mar 29, 2016 09:26 PM
Qu4ttro
Cayenne 958
11
Sep 4, 2015 01:35 PM
PACE
Aug 26, 2015 07:59 PM
