Headlights malfunctioning
Old Dec 27, 2008 | 01:19 AM
Valley996TT's Avatar
Valley996TT is just really niceValley996TT is just really niceValley996TT is just really niceValley996TT is just really nice
I have a 2003 TT and I am having some issues with both my headlights. They do not always turn on when I turn them on. The parking lights, front fog lights and rear "fog" light come on like they are suppose to. I have to turn the lights on and off several times before they come on. Sometimes they don't come on until I have been driving around for about 5 minutes (with my fog lights on), then turn them off and on again. Both headlights do this; that is, they are either both on, or they are both off. Any idea what the problem may be?
Old Dec 27, 2008 | 05:22 AM
Turbo Fanatic's Avatar
If they both come on and off at the same time, it's probably something electrical upstream.
If they come on and off independently, could they be loose? The headlights slide in as a complete assembly and then get tightened via a hex wrench (the tool is in the black plastic tool container in the front trunk). If the hex bolt wasn't tightened when the bulbs were replaced, they will definitely be flickering on and off as you drive, but probably not at the same time. The bigger question is why are they loose? Was the car in an accident? Headlights are not usually a maintenance item. What's the mileage?
Old Dec 27, 2008 | 07:06 AM
dmilzoff's Avatar
dmilzoff is infamous around these parts
I had the exact same problem with my '03 last summer. I had to switch the lights on and off 2 -3 times before the lights would come on. After a while, I was afraid it wouldn't come on at all. A bummer when you are away from home at nite.
I replaced the headlight switch (myself). It's been fine.
Old Dec 27, 2008 | 09:17 AM
wross996TT's Avatar
Either the headlight switch or the ignition switch (with the lights turned on can you jiggle the keys in the ignition and get them to come on/off?)
Old Dec 27, 2008 | 02:47 PM
Thanks for the replies guys. It seems that I have the same problem as dmilzoff and will look to replacing the light switch.
Dmilzoff, how hard was it to replace and where did you get the replacement switch?
Old Dec 27, 2008 | 08:09 PM
PeterK's Avatar
PeterK is infamous around these parts
Mine started to do the same, replacing the headlight switch did the trick! I think this failure is quite common on 996 since my dealer kept a few in stock.
Old Dec 29, 2008 | 10:35 AM
dmilzoff's Avatar
I got the part from Suncoast. I first tried removing the part to use electic cleaner but the part is all enclosed and I couldn't get the cleaner to the switch surfaces. I don't remember that replacing the part was very difficult. I believe that you needed a small allen wrench to remove the switch handle.
Old Dec 29, 2008 | 03:33 PM
Thanks for the responses guys. I just ordered the headlight switch from Suncoast. They had the best price I could find. I hope this fixes the problem. Will report back once the part gets here and I install it.
Old Jan 9, 2009 | 11:22 PM
You guys were right. It was the headlight switch. It took me about 15-20 minutest to put in the new part. Problem solved. Thanks again guys.
DYL 911
Oct 20, 2025 05:08 PM
adnanm3
Oct 25, 2016 08:38 AM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
DYL 911
Oct 1, 2015 02:47 PM
ECS Tuning - BMW
Sep 29, 2015 01:18 PM
