Suspension raised (again)
Old Sep 17, 2004 | 08:07 AM
Red Devil's Avatar
Red Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to all
I had my H&R coilovers raised up an additional 3/4 inch from the original 1/4 last time. The original H&R design didn't allow for much front adjustment and they redisgned the front spring to give a more streetable adjustment range. Mike at AWE hooked me up with the springs (thanks) and I watched my mechanic install them, raise the rears, check the corner weights, adjust camber and toe in just about 3 hours yesterday. My initial observations are the new springs seem more compliant when hitting bumps. Otherwise, I can't say I feel anything else different, which is good because I liked it before. It was interesting to see how much inner side wear existed on the rears compared to the rest of the tire. He said that is common on these but it's not an area you can easily see and I'd recommend you check yours from underneath with a good flashlight. I've only got 4K on these Yoko's and I'd be lucky to get another 2K. I'm hoping to get a tire with a little more sidewall than the 315/25's. Anyone know offhand what the closest 19 plus tire is to stock OD in the rear besides the 315/25? I was prepared to put in a new suspension but don't think it will be necessary now. I have room to go up more if needed but think the profile looks just right now. I'll post a picture if it stops raining here.
Old Sep 17, 2004 | 08:27 AM
vipertestarossa's Avatar
vipertestarossa is a jewel in the roughvipertestarossa is a jewel in the roughvipertestarossa is a jewel in the rough
Michelin PS2's have a tall sidewall, much more so than Conti's or anything else
Old Sep 17, 2004 | 08:35 AM
Sean's Avatar
Sean is infamous around these parts
ditto....ken, tony, ron and i have likewise.
Old Sep 17, 2004 | 07:11 PM
Red Devil's Avatar
Will the taller sidewall make a more compliant ride at the same aspect ratio?
Old Sep 17, 2004 | 09:58 PM
Sean's Avatar
same
Old Sep 19, 2004 | 06:31 AM
Red Devil's Avatar
If I currently run a rear 315/25 on the 19 inch will a 305/25 definately fit? On the front will a 225/35 fit on the 19 if I currently have a 235/35? TIA
Old Sep 20, 2004 | 07:06 AM
Sean's Avatar
i think the rim width is a faactor is determining the appropriate sized tire.
Old Sep 23, 2004 | 06:19 PM
Red Devil's Avatar
I'm happy to report that after installing the new H&R front springs, not much has changed. The car seems to handle road bumps with a less jarring effect and clearance is up 1 inch. There are some pictures here showing before and after (2nd page):
http://community.webshots.com/album/59113196ohatDN
Old Sep 24, 2004 | 02:14 AM
drbill's Avatar
drbill is infamous around these parts
boy, you Italians can't get enough of red!
danyoP4S
Sep 30, 2021 05:06 AM
Kai@ELITEMS
997 Turbo Vendor Classifieds
Nov 25, 2015 06:39 AM
Kai@ELITEMS
996 Vendor Classifieds
Nov 25, 2015 06:32 AM
Kai@ELITEMS
997 Vendor Classifieds
Texas1
Sep 20, 2015 09:12 AM
