Yet another problem
Old Jan 21, 2009 | 09:26 PM
colesporsche's Avatar
colesporsche is infamous around these parts
Stock air box. An i flashed my Porsche over 4 years ago with a upsolute. So yes. That bad? But theres no more cel now
Old Jan 21, 2009 | 09:43 PM
ANd I bet it got colder thus the maf issues... = Upsolute
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jan 21, 2009 | 09:48 PM
raineycd's Avatar
Amazing MARKSKI, just amazing! You really know your crap!
Old Jan 22, 2009 | 02:33 AM
stevo996tt's Avatar
stevo996tt is infamous around these parts
have the same problem, psm abs errors all the time
Old Jan 22, 2009 | 02:58 AM
Turbo Fanatic's Avatar
Get a MAF. The car is rich witha bad MAF, You will blow your cats if you ignore it.
Old Jan 22, 2009 | 07:25 AM
blakez's Avatar
blakez is infamous around these parts
I could be wrong, but don't Maf's have a set resistance value. Could he simply check the resistance and see if it is with in tolerance? If it is then move on to something else, if it is not in tolerance then replace the maf.
Old Jan 22, 2009 | 09:30 AM
But i didnt have a problem with until 4 years later. Could that be markski? So is it my Ecu or maf?
Old Jan 22, 2009 | 10:08 AM
blakez's Avatar
This might help... found this in another thread.
" Hot-film MAF sensors use a centrally-heated film element. These sensors function on the electrical principle that resistance increases with temperature. As intake air moves past the film, the cooling effect causes a measurable drop in resistance, and thus lower voltage is required to maintain the prescribed temperature. The MAF control unit is sent a reference voltage of 5V, and returns around .4V to.5V at idle and from 4.5V to 5V at full throttle. Based on a fixed data set, an accurate assumption of air mass is made. This information is sent to the ECU for appropriate adjustments to timing and AFR."
Old Jan 22, 2009 | 10:20 AM
blakez's Avatar
Found this from 07 I think.
"here is the technical answer...
The stock MAF makes it's peak voltage at 1400 kgs/hr, or 51.33
lbs/min, and at 10hp/lb/min, that's 513hp max. But those engine's don't
make that efficiency, so maybe 490 or so hp, they're pegged.
Now, the input voltage is 12v, so the thing keeps making more output
voltage, but the ecu has a diode clamp on it to keep it from exceeding that
voltage, so the thing just keeps drawing more and more current till it pops."
Old Jan 22, 2009 | 11:01 AM
blakez's Avatar
I know this is not for a p-car, but same concept. I was doing some reading and it reminded me of my turbo Z. The 300zxtt maf is only good to 485hp, after that you simply split the intake i.e.(one side gets stock maf and other side gets no maf) hence the car gets the air it need but it thinks it only has 485 hp.
http://www.jimwolftechnology.com/cus....asp?PartID=44
Old Jan 22, 2009 | 01:29 PM
stevo996tt's Avatar
i changed it 3 times. still same thing...
Old Jan 22, 2009 | 02:38 PM
Steve,
Do you get the psm, and abs under full throttle? Mine is fine unless i hit it and get over 5k and a bar boost. still seems slugish from a start to tho.
Old Jan 22, 2009 | 03:42 PM
stevo996tt's Avatar
i get it when i slow down to stop only. never when boosting it
Old Jan 22, 2009 | 03:49 PM
blakez's Avatar
Question Texas
Are you still receiving the same warning lights today? I only ask because it is nearly 80 degrees in Dallas today.
cockneymike
Oct 22, 2015 06:00 PM
Zero911
Sep 24, 2015 06:33 PM
vogz
Sep 19, 2015 01:02 PM
nal991
Sep 11, 2015 09:05 AM
flewis763
Sep 10, 2015 01:08 PM
