battery replacement
Old Feb 4, 2009 | 04:51 PM
faukxyhall's Avatar
faukxyhall is infamous around these parts
new battires are a pain in the ***
Old Feb 4, 2009 | 04:54 PM
s14roller's Avatar
s14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to behold
BTW - if you don't have access to electrical socket for the tender, i'd look into getting either a battery kill switch (the type that has a metal screw that contacts) or just pull off the negative. if you end up letting it sit for a week or 2, it's hard to say if it'll want to start.
Old Feb 4, 2009 | 06:29 PM
Verde's Avatar
Verde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond repute
Does anyone have any experience with those Braille batteries? 11-17 lbs is remarkable. If so, what model/bracket? And, for the Optima, what bracket do you use? My current battery is the original on an '05 997S car, and it just seems to be cranking slower and slower. I have had it on a Battery Tender for a day or so, and it won't go to 'green'. Not good.
Old Feb 4, 2009 | 09:59 PM
drlaw99's Avatar
drlaw99 is just really nicedrlaw99 is just really nicedrlaw99 is just really nicedrlaw99 is just really nice
The following is a link to a bracket that I recently purchased. It works with an Optima Red Top 34/78 series. Weight is 38 pounds. 800cca at 0 degrees and 1000cca at 32 degrees. Some drilling to mount the bracket I understand, but minor. http://cgi.ebay.com/ebaymotors/ws/eB...m=150323879702
Old Feb 4, 2009 | 10:55 PM
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
There was a DIY thread on ....I think it was Rennlist that showed how to make a mounting plate for the Optima battery....IIRC it was pretty well done and looked good.
Old Feb 5, 2009 | 06:12 AM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
Originally Posted by David9962000
I got a Die Hard battery( Type E2) from Sears for $135 and it's 20 LBS lighter, it fits in the OEM tray with the OEM bracket. It has a 3 years warranty and it's been great, no problem.
I just searched the site and could not find "type E2"...
Could you give more data: model number, size, etc. TIA!!!!
JB
Old Feb 5, 2009 | 07:30 AM
jpflip's Avatar
I got a Delco UN2794/8/3 part#4993-6YR. Weight:45 pounds. 1000 amps cold cranking power 825 A. I paid $181.15 (with all the canadian taxes). No problem so far. Plenty of power...
Old Feb 8, 2009 | 04:18 PM
John H.'s Avatar
John H. has a spectacular aura aboutJohn H. has a spectacular aura aboutJohn H. has a spectacular aura about
JB
Yes, please more info on the Sears battery. The lightweight batteries work, but they require a battery tender all the time which can be annoying. If you live in an area which get's below 40 degrees, you will have isssues if you park your car overnight w/o a tender. They're a good option for a track car.
In my opinion and many others, the Optima isn't the battery informed people purchase - sort of like Monster Cables. They aren't reliable and offer no advantages in weight or cranking. Pluses are they're "pretty" and sealed which means they're potentialy mountable inside the vehicle. Inside mounting isn't practical in this application.
JH
pwdrhound
Sep 16, 2021 02:27 PM
Jul 29, 2019 11:13 AM
DetomasoGTS74
Nov 11, 2015 09:01 AM
OldBoldPilot
Aug 24, 2015 04:00 PM
DSCOFF
Aug 23, 2015 01:22 PM
