ev dvs
Old Feb 6, 2009 | 07:32 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
ev dvs
a friend just loaned me a set of evo dvs anyone know if they are louder ??
Old Feb 7, 2009 | 01:30 AM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
than OEM or any others?
Old Feb 7, 2009 | 09:33 AM
unvmy996's Avatar
all those DV's ..forge , evo , bailyes , etc , when not vented to atmosphere make the same noise , you will not get that overly loud whoosh you get witha blow through system ...
Old Feb 7, 2009 | 04:07 PM
smooth_operator's Avatar
smooth_operator is infamous around these parts
you will get better turbo response over stock, no noise difference.
Old Feb 7, 2009 | 06:42 PM
ard's Avatar
ard
Really? Always heard that changing DVs was prophylactic, that the stocks will fail so might as well replace them sooner rather than later...
Old Feb 7, 2009 | 06:46 PM
put em in
just went for a test drive, the car runs great but no woosh.... still can't figure out where it went it was there until i put evo piping in and now the car runs faster but no woosh
Old Feb 7, 2009 | 06:49 PM
ard's Avatar
ard
Maybe you hose was loose or disconnected and you were hearing a woosh...when you replaced the hose you fixed it?
Old Feb 7, 2009 | 09:52 PM
colorinc's Avatar
colorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond repute
wow your still having issues with this ... here is a solution call todd at protomotive and order his air system and be sure to get the piping so it fits the tial blow off valves.. im sure u wont miss the woosh then!! or get awe straight pipes and you wont have to worry about hereing anything at all
Old Feb 8, 2009 | 04:53 PM
prophylactic
a device, usually a rubber sheath, used to prevent conception or venereal infection; condom.
the stock units are a diaphram design, the aftermarket are a piston design. if you are stock, stock is fine. any upgrades you need to replace them.
Fadi
Oct 5, 2015 12:14 AM
AdamNoone
Aug 31, 2015 07:45 PM
GoingFast
Sep 11, 2009 03:26 PM
steve harris
Jan 11, 2009 07:19 PM
Alpha
Aug 19, 2007 04:49 PM
