Newbie...Is 0.7-0.8 bar full boost at full throttle, also
Old Feb 4, 2009 | 10:54 AM
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
I was in third gear WOT and the PCM failure and ABS failure lights came on, pulled over restarted and no problems w/ 30+ mis. of hard driving. Also the rear spoiler wont come down one side seems stuck and the other is 1/4 way down, switch wont work?? Thanks.
Old Feb 4, 2009 | 11:48 AM
Seattle996's Avatar
Seattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond repute
Good luck on the spoiler.. I just pulled the fuse. I've had problems with it before, had to replace the hydraulics on one side.
But before you waste your money, there is a thread on bleeding the hydraulics. If you leave your car siting for awhile (mine sat for 2 months) with the spoiler in the up position, it tends to decrease pressure and hence the thing wont go up all the way anymore.
Oh.. and try some WD40 as it seemed to work on the passenger side. But my driver side has no pressure to go up all the way.
Old Feb 4, 2009 | 12:12 PM
MechanicalEng's Avatar
MechanicalEng is infamous around these parts
yes, the stock boost is supposed to be .7 - .9. I have the same issue with the PSM/ABS light coming on, I will take the car back to the dealer in a couple of days to get it resolved. The spoiler issue is a common problem with these cars, unfortunately it is an expensive item to replace. Do a search on the forum, I know that someone here took it apart and figured a way to fix it..
Good luck
Old Feb 4, 2009 | 12:14 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
with a little force you can push the stuborn side down with your hands. Just lube up both pistons with WD40 first. Once it's all the way down. Try your switch again. Should work fine.
Old Feb 4, 2009 | 01:33 PM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
My name is Todd & I slept at Holiday Inn last night.
Old Feb 4, 2009 | 01:50 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
0.7-0.8bar is normal with stock ecu on full boost.
Old Feb 4, 2009 | 02:38 PM
ttboost's Avatar
I don't know Todd, I think Paulie has fallen out of love with you??? Did you hurt his feelings last weekend?
Old Feb 4, 2009 | 02:48 PM
Just trying to hook a brutha up....
Old Feb 4, 2009 | 02:51 PM
Just put enough beer & hambergers on it & it will be fine.When I had my turbo every time I parked I put the spoiler up and put a open bar sign & tip jar on it...
Old Feb 4, 2009 | 03:25 PM
That won't work Sherlock. If one side's up and the other side's down, then the beer and food will just slide right off, duh! Sorry OP. When Paulie wiggles out of his straight jacket, he goes right to 6 Speed.
Old Feb 4, 2009 | 03:26 PM
ttboost's Avatar
OK...now that was funny!!
Old Feb 4, 2009 | 03:31 PM
ttboost quit crawling up Todd a$$.Todd the angle of the spoiler is perfect for the flow of beer,kind of like a beer bong.
Old Feb 5, 2009 | 09:14 AM
art4iza's Avatar
Nice to see so much love going on here. Any update on that ECU?
BlackMarketRacing
Dec 8, 2015 01:49 PM
007AMV8
Oct 19, 2015 09:55 PM
PelicanParts.com
Aug 26, 2015 04:25 PM
PelicanParts.com
Aug 26, 2015 04:24 PM
magoochi
Aug 23, 2015 05:54 PM
