Track prep
Old Feb 4, 2009 | 11:09 PM
av2's Avatar
av2
av2 is infamous around these parts
Track prep
I want to get my car ready for upcoming track events. As far as fluids go, what are the best choices out there for the TT tip? I am currently thinking about the following fluids:
Tip tranny: Redline D4 ATF - 9 liters
Diff: Redline diff 75-90 - 1.2 liters
Power steering: Pentosin CHF 11S - 2.26 quarts
Brake Fluid: Motul RBF 600 DOT 4 - 0.67 quarts
Engine Oil: Mobil 1 (5W-40) - 8.5 quarts
Radiator Fluid: OS Services Genuine Coolant plus a bottle of water witter.
Anything else I should replace? I've heard great things about Toyota's red coolant for racing conditions with 20% mix.
Thanks,
Old Feb 5, 2009 | 07:08 AM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
What brake set up do you have?
Old Feb 5, 2009 | 07:42 AM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
Thanks,
It's nice to replace fluids, but in my opinion, unless you are close to the end of the normal cycle for them, most of these changes are not necessary. The radiator flush alone is going to run you $250.
You *do* need to change brake fluid. You'll need two quarts of the Motul. One will do the change, but not leave you with much to top up if you need to bleed the system.
Just my 2 cents.
Jon
Old Feb 5, 2009 | 10:43 PM
av2's Avatar
av2
I am running on stock brakes.
My car is running on old fluids other than the motor and brake fluids, so I figure it's time for a change before hitting the tracks.
Old Feb 6, 2009 | 06:17 AM
Al Norton's Avatar
If it were mine, I would switch brake fluid to Castrol SRF. It's quite expensive but so is going off th track if you boil your brake fluid. With stock pads you will still have the possibility of pad fade if you run hard but at least you would lessen the chance of fluid boiling.
Old Feb 6, 2009 | 06:36 AM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
+1.
I use SRF. It is the most expensive one, but it keeps its properties over time way better (as moisture gets into it) than any other fluid. So, for me, one flush per season......
80 bucks a liter, one bottle or so for a flush....
Jeff
Old Feb 6, 2009 | 07:06 AM
audikp's Avatar
audikp is a splendid one to beholdaudikp is a splendid one to beholdaudikp is a splendid one to beholdaudikp is a splendid one to beholdaudikp is a splendid one to beholdaudikp is a splendid one to behold
I would suggest getting some track pads as well...
Old Feb 6, 2009 | 02:16 PM
FAST FWD's Avatar
A lot of this discussion depends on your skill level. My experience is that the closer to novice you are, the harder you are on brakes. You're not going as fast, but that is in part due to overusing brakes. Track pads are definitely a good idea. There is some religious fervor on this topic - search the forum. I prefer Pagid yellows, others here will tell you Pagid orange, or orange/front - black/rear, or something else. I wouldn't recommend the mixed pads F/R unless you re an experienced track driver.
I use Motul. It's a factor of 5 times less in cost than Castrol SRF. I ran several hundred miles at Road America each day for three days in a row with no issues, and that is one of the fastest tracks in the country. Nothing wrong with Castrol, except the price.
My 2 cents.
Jon
Old Feb 6, 2009 | 07:14 PM
Mikelly's Avatar
I would NOT replace the Factory fill on the DiFF with Redline. Stick with the DELVAC OEM factory fill.
http://www.lufteknic.com/Merchant2/m...ode=lubricants
Mike
Old Feb 6, 2009 | 08:42 PM
Mike
+1
Same on the tranny. I know people use other stuff. I just redid my tranny due to 2nd gear pop-out and DAS put stock stuff in (and there were lots of cup cars in his shop). I used the stuff Mike posted too...same stuff more or less. It is NOT the same as generic mobil 1 gear oil. Get the Delvac or get the dealer stuff (which costs more).
Jeff
Old Feb 6, 2009 | 08:49 PM
Mikelly's Avatar
Couldn't agree more on this one... I've used Motul (and GS610) for two years with zero issues... Great stuff at a great price!
Mike
My 2 cents.
Jon
Feelgood MD
Mar 24, 2016 09:35 AM
WearyMicrobe
Dec 10, 2015 04:06 PM
Texas1
Sep 20, 2015 09:12 AM
Korntera
Sep 15, 2015 08:20 PM
oo7
Sep 10, 2015 08:08 AM
