Cobra Misano Seats for 996
For future reference and easy search on these seats I thought it worth a little write up.
Cobra Misano's are a great light weight reclining sports seat, well constructed and very good quality. I had shopped around a fair bit as I need recliners (kids ride in the car every day) but want to be able to use race harness for track days (harness bar is next project - removeable of course). Similar seats would be from Recaro and Corbeau for example but I ended up lumping on these. The 996 has a tight fit for seats, non-electric Recaro Sports would have issues fitting and I was not interested in the electric creature comforts, more on functionality and matching appearance with weight saving as an added bonus - these are sooo much lighter than stock. The Misano 30s are a subdued black colour that really compliment the graphite grey interior, they have plenty other options for colours (as do the other manufacturers) but I was wanting to avoid shiny black and lighter greys.
Thanks to some tips from vincentdds the install was pretty easy. You have to remove the inboard recliner **** (pops off), cut down the protruding ****, and then cap it - I used an axle cap (3/8") from Lowes. You have to decide on seat height also, the seats have tabs with 3 height options, to go lower you have to hacksaw off the unwanted mounting holes, as with a 996 the bases wont let the tabs protrude down. I ended up with the lowest mounting position on both sides, seat sits minutly higher than OEM at its lowest I think, but plenty low for me (6') with helmet on and for daily use. You mount the seatbelt recepticle to the inside of the tab on the seat base for it to fit snuggly. Base (in this lowest case) mounts in to the car first, then the seat with the rails/sliders mounts on to the base. We also lifted up the carpet under the B pillars and cut away some plastic there, that lets the seat slide all the way back without the outboard recliner ***** getting restricted. Carpet back in you can't tell any change.
Install was pretty easy but I had an experienced hand helping me. If you are Houston based I'd recommend going through Moterwerks to get the seats and have them install.
Mounting tabs: Seats in:
Btw, check this link out for the harness bar.
https://www.6speedonline.com/forums/...rness-bar.html
Edwin
Edwin
There aren't a ton of seat options that actually fit our cars and then the harness use is the other factor that needs to be keyed in, took a fair amount of research and almost orders before going for these.
Edwin
Edwin
I'll weigh the OEM's when I get a chance, maybe tonight. The Misanos without base I think are a mere 29lbs each - correction - 24lbs - full carbon fibre shell, the base weighs a bit though.
boss what do those seats cost?
and which exactly are those ? cuase i tried looking for them but they dont seem to look liek yours especilay where the seating is and the back parts where its cross stitched , the ones i saw are dont have that .
Wow that looks fantastic in your car. I am glad you choose them. I find myself admiring at mine every night come home after work.
FYI, the seat and slider weigh 40lb. vs stock 60+lbs. There will be thinner aluminum ***** available soon.
Depends on how/where you get them. Sube is the US importer.
Hoping to see Motorwerks here in Houston as a dealer - You Houston area guys give them your support and they may be able to get better prices - plus they know how to get them installed - sorry, shameless plug, but those guys, especially Akram, have been very supportive to me. Wish we had the seats in the car before the Auto show, I am sure that would have kicked off some orders.
Another comment on price for the last post, these are comparable to Recaro Sports Topline, and Sportster CS in price. Value is hard to say as both companies make excellent seats.
Slide to the bottom of this page (link) and you will see them.
I'll get a weight on my stockers tonight, they feel heavier than 60+ with the electrics and heat etc.
Originally Posted by Mikelly
Those seats look absolutely killer and are a good compromise.
Mike
Mike
I'd be interested if Akram coulld get a GB going
Edwin
