How hard is it
Old Feb 5, 2009 | 12:39 PM
giggalo's Avatar
giggalo is a splendid one to beholdgiggalo is a splendid one to beholdgiggalo is a splendid one to beholdgiggalo is a splendid one to beholdgiggalo is a splendid one to beholdgiggalo is a splendid one to beholdgiggalo is a splendid one to behold
How hard is it
to change the instrument cluster to White? I have the faces but have no idea how to pull the dash/cluster.
Old Feb 5, 2009 | 03:15 PM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
Lord for a minute I thought you were my wife.
Old Feb 5, 2009 | 05:04 PM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
Should be fairly soft with proper instructions;P I always thought thou that once you take the cluster apart there is a way to tell it was messed with.
Old Feb 5, 2009 | 05:50 PM
dublinoh's Avatar
dublinoh is infamous around these partsdublinoh is infamous around these parts
I did a search on Rennlist...I should tell you that many threads warned against this as a DIY project if you were not experienced...and this is for a Boxster so the same? But here it is:
http://www.iwantaporsche.net/cluster.htm
This might be helpful for removal of the cluster:
http://www.renntech.org/forums/index...434&#entry2434
Old Feb 5, 2009 | 06:23 PM
RiA's Avatar
RiA
RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !
I've done it a few times - on different P-Cars. It's not hard, but you need to take your time.
As a tip, I would suggest that you take good clear digital pictures of where your needles are relative to your gauges "with the ignition in the ON position."
Once you have the new faces in place, plug your cluster back into the connectors and turn your ignition back on to place your needles in the appropriate location.
Then turn the ignition back off, pull the cluster and reassemble the rest of the parts.
This way, you'll be certain to have the needles indicate the proper values in the guages.
PM me if you need more help.
Old Feb 5, 2009 | 08:54 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Two screws on each side, fairly easy. Should take about 20 min. tops.
BLKMGK
Sep 19, 2015 03:51 PM
Korntera
Sep 15, 2015 08:20 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
vchris
Cayenne Turbo
Sep 11, 2015 02:52 PM
