Suspension Made Simple?
Old Aug 12, 2009 | 03:46 AM
  #76
Mikelly's Avatar
Thanks. I have a number of years (going on two decades actually) of experience with suspensions. I also used to custom fabricate and sell a product line of suspension parts for another marque for about 4 years.
Mike
Old Aug 12, 2009 | 07:21 AM
  #77
mose55's Avatar
mose55 is infamous around these parts
Sounds like your suspension set-up (pretty much the same as mine) is too stiff for the roads you drive. My car definitely does not like undulating pavement with ridges and dips in them...PSM kicks in, car is not planted, etc. However, on the track, it does pretty well which is where it spends most of the time anyway.
GL
Old Aug 12, 2009 | 07:52 AM
  #78
kwerks's Avatar
kwerks has a spectacular aura aboutkwerks has a spectacular aura aboutkwerks has a spectacular aura about
has anyone tested on racing slick tires? not MPS.. with some data?
Old Aug 12, 2009 | 09:41 AM
  #79
heavychevy's Avatar
Yes, what kind of data you looking for?
Old Aug 31, 2009 | 05:47 AM
  #80
ABCar's Avatar
ABCar is infamous around these parts
This is a great thread...thank you. I am saving as my reference for future work.
Old Sep 27, 2009 | 04:02 PM
  #81
rafiki's Avatar
rafiki is infamous around these parts
KW Club Sport coil overs vs V3
Anyone here have any experience with the KW Club Sport coil overs?
I was wondering if they are any harsher on the road compared to the KW V3?
My suspension shop have recommended these above the V3 because, apparently if you go with CS, you do not have to upgrade the stock sway bars and the CS already come with camber plates. (He recomemnded GT3 camber plates with the V3).
Sounds like a more cost effective solution for mostly road use with occ track.
Interested in your feedback.
Old Sep 27, 2009 | 04:14 PM
  #82
Mikelly's Avatar
I don't know why you'd want to keep the stock swaybars and endlinks... in my opinion, they're very minimal, extremely limited in use and the endlinks are downright dangerous when they break (and they will).
Mike
Old Sep 27, 2009 | 04:24 PM
  #83
rafiki's Avatar
Thanks Mike.
I think the KW CS come with new end links, but I could be wrong...I'll check.
As far as the sways, I always planned to go with the GT3 rear sway, but the suspension guy who has set up quite a lot of Porsches for road and track said for my use, it's not necessary with the CS becasue the rear springs are much stiffer.
I plan to track the car only a few times a year at most.
Happy to listen to the experience of others.
Old Sep 27, 2009 | 04:30 PM
  #84
Mikelly's Avatar
Are you planing to run a front bar?
The springs do one thing very well... They also do a couple of things that swaybars help counter-act, and a lot of that helping to counter-act are the cycles of wound compression/ cyclic harmonics that can cause more harm than good.
Regardless the spring rate, I'd want sufficient adjustment in a sway bar to be able to combate the cyclic harmonics both front and rear. That's just me.
Mike
Old Sep 27, 2009 | 04:39 PM
  #85
rafiki's Avatar
That's way more technical than I've considered, so I'll put it to my suspension technician.
I was initially going with the FVD Sport PSS9's, links and rear sway.
I know quite a few people here don't run front sways with PSS9 / PSS10.
However, I've only just started seriously looking at the KW's, so unsure of the best setup for my use. If I need front and rear sways, are the HR's the best to go with?
Old Jan 24, 2010 | 05:33 AM
  #86
Mikelly's Avatar
Didn't want a medal (but appreciate the jesture) but would have much appreciated valuable info like this remaining STICKIED in the 996TT TECHNICAL FORUM!!!
ADMINS why even bother with a model specific vendor forum if you're gonna ***** US OUT to the vendors HERE???
Mike
Originally Posted by kwerks
Mikelly you deserve a metal for this thread. Someone sticky this thing!
Old Jan 24, 2010 | 06:52 AM
  #87
heavychevy's Avatar
Edit the title and add 60-130 or Texas Mile and maybe that will work?
Old Jan 24, 2010 | 07:32 AM
  #88
Mikelly's Avatar
Dez, as you well know (saw you there this AM) I'm moving all my tech stuff elsewhere...
It's their sandbox...
Mike
Old Jan 24, 2010 | 08:59 AM
  #89
kwerks's Avatar
I guess Pioneer Head Units deserve a sticky did anyone request that garbage?
Old Jan 24, 2010 | 03:04 PM
  #90
Mikelly's Avatar
I'm sure they did man, probably a vendor selling the units...
Mike
