larger injectors?
Old Mar 8, 2009 | 02:15 PM
  #31
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
I agree, I have K24/18s just like Tom. At my power level a 5 bar is fine. You simply don't need injectors yet.
Old Mar 8, 2009 | 02:21 PM
  #32
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
From a "textbook" tuning prospective, your existing set up does need injectors.
At "650" crank hps, you will be at 95%+ injectors duty. We try never to tune injectors passed 85% of their capability.
Old Mar 8, 2009 | 03:14 PM
  #33
cjv's Avatar
cjv
Moderator
Originally Posted by steve harris
cjv anyone other than kevin with the formula? ok so i mean who else might know?
thanks steve
Here you go Steve.
http://www.rceng.com/technical.aspx?...JH3gDmKsnicojz
Old Mar 8, 2009 | 04:30 PM
  #34
Prche951's Avatar
Your talking about the K24/18 setup right?
If you are talking about the K16/24's how much power gain did you see? or was it more safety margin.?
Old Mar 8, 2009 | 05:08 PM
  #35
Dr_jitsu's Avatar
I have seen w/ my own eyes in the real world that injectors do indeed make a difference for the 24/18's. About .4 seconds in a 60-130 run which is about 2 car lengths.
Old Mar 8, 2009 | 06:28 PM
  #36
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
We haven't turned up the boost to fully yet on our setup, but I'm willing to bet with the extra boost we can now safely run with our injectors, we'll see 50-75hp more on race gas with K24/18Gs than without. That and it's nice to know that at 600whp we're at 55% duty cycle vs. 95% that's a MUCH better tuning window, and leaves more than enough ceiling should something unexpected happen either with gasoline being used, or an overboost.
Old Mar 8, 2009 | 07:07 PM
  #37
ReeknHavic's Avatar
Wes, how high are you going to turn the boost up to on race gas?
This is still a stock bottom end car isn't it?
Old Mar 8, 2009 | 07:39 PM
  #38
tom kerr's Avatar
that was exactly my point as well , just articulated better!
my injectors were at 80%
Old Mar 8, 2009 | 07:44 PM
  #39
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
I have a question? How much more agressive can you be with Q16 vs C16 with timing?
Robert
Old Mar 8, 2009 | 08:15 PM
  #40
justinn's Avatar
justinn is a splendid one to beholdjustinn is a splendid one to beholdjustinn is a splendid one to beholdjustinn is a splendid one to beholdjustinn is a splendid one to beholdjustinn is a splendid one to beholdjustinn is a splendid one to behold
not too much... you gain the oxygenation more than being able to increase the timing
Old Mar 8, 2009 | 08:26 PM
  #41
robmd99's Avatar
Justin
Came across one of you tune beast yeasterday.... Karem D black bich! Now why did you choose to run Q vs C in that one?
Robert
Old Mar 8, 2009 | 08:46 PM
  #42
onelove's Avatar
So far I've turned her up to 1.32 bar and made 594. I've been running MS109 in the car since we put the turbos on for safety as we get the map right for the 1,000cc. I like to be safe when setting up a boost controller and tune, it's better to have race fuel and watch the logs on initial setup to get an idea wherey ou should be on pump, then go back to pump and relog to verify you are safe. We just installed a set of intercoolers on the car, and if all goes as planned and our new diff gets installed in time, I'll turn her up to 1.45-1.5 bar this week and see how she does. Probably leave it there for TX2K9 so that Nero can have some fun in Mexico. The engine is bone stock with 66k miles, I'd much rather use this car as a guinea pig than a customers car.
Robert
Q16 is pretty much oxygenated C16, they're similarly priced so most just switch to Q with minor tuning changes. If you want to get more aggressive with timing you will likely want to swap to VP Import.
Old Mar 8, 2009 | 09:37 PM
  #43
robmd99's Avatar
VP import? Wow that is a new one. I use VP vit C (C16) when I am on high boost. But so many Supras are now running Q and they always seem to be a head of the Porsche community by a few years... just curious.
Robert
Old Mar 8, 2009 | 10:45 PM
  #44
onelove's Avatar
Robert
Most of the BIG power supras run import. C16 and now Q16 are very popular as it's a more common tuneup and a considerable savings over Import. We've been running import in our supra for years, but doubt it will find it's way into our Porsche any time soon. Most tuners have thier opinions, experiences and most importantly preferences on what they feel works best, so as with anything consult ur resident expert before experimenting.
Old Mar 9, 2009 | 05:29 AM
  #45
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
Jitsu has no idea what he is talking about.Sean please explain the real world example you are talking about.
