larger injectors?
larger injectors?
here's what the 01 has is it time for fuel rails and injectors maybe pumps?
gais flash race gas , headers, evo ics, europipe loud,ssk,evo air box,fresh air kit from evo (from the air box to the turbos) red hose kit, 100cell cats, think thats aout the whole package.
what do you guys think the hp to the wheels is and should be thinkin about more fuel del? thanks in advance steve
what do you guys think the hp to the wheels is and should be thinkin about more fuel del? thanks in advance steveWhat turbos do you have?
indeed that 18 guys are running 5 bar fprs and there turbos flow alot more then yours and there fine . and deff dont need fuel rails , or pump.
they do just fine bro , i like to do the inectors rather then the 5 bar , just for safety. 60 lbs siemens.
I dont think you need new injectors for your turbos. Remember you need a new map even for just a FPR mod...
thanks guys will look into the fpr stuff. whats the thought o remaping for a new fpr? am using a giac race file as i remember it's for the k24s even thought i'runnig thek16 hy?
If the ecu does not "know" that higher FPR or larger injectors are present the car will run too rich at low speed, foul plugs, and perform suboptimally.
