Running RWD on rolling road
Old Mar 8, 2009 | 06:24 PM
Neil A's Avatar
Neil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud of
Sorry for the newbie question but .
I have notice a lot of you guys convert to rwd to get a power run on rolling roads, is there any reason behind this apart from only having 2wd dynos local.
Also is it a big job to do, as my local car club is about to hold a rolling road day but its a 2wd dyno only.
Old Mar 8, 2009 | 06:32 PM
GT3 Chuck's Avatar
Administrator
loss of weight and rotating mass
Old Mar 8, 2009 | 06:55 PM
heavychevy's Avatar
What is rolling road?
Old Mar 8, 2009 | 06:56 PM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
You should be able to drop the driveshaft in under 5-10 minutes.
Most do it for the 70-75lb weight savings, or to make RWD dyno easier.
Old Mar 8, 2009 | 07:03 PM
Neil A's Avatar
Sorry thats what we refer to a dyno as over here.
So if it was just for a power run up on a 2wd dyno its just a case of disconnecting the front shafts at the diff.
Old Mar 8, 2009 | 07:22 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Loss of one lb is almost equivalent to gaining 0.1HP, you do the math. If you save 75 lbs=7.5HP gain. Hope this helps.
Old Mar 8, 2009 | 07:26 PM
heavychevy's Avatar
Just for the dyno all you have to remove is the input shsaft that goes from the rear to the front. Easy to do as mentioned. A full conversion removing the front driveshafts is much more difficult (at least one part of it).
There are some DIY's posted here if you want to try it. Even a noob can do it.
Old Mar 8, 2009 | 07:35 PM
tom kerr's Avatar
dont you have AWD dynos in Scotland?
Old Mar 9, 2009 | 05:05 AM
Neil A's Avatar
Hi Tom yes there are a few 4wd dynos in Scotland mostly Maha and Dyno Dynamics, was only asking as the place my local club are holding a dyno day at only have 2wd. May have a word with the dyno operator and see if he has ran any 996tt's in this way before.
Old Mar 9, 2009 | 07:19 AM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
in order to dyno AWD 996TT specific dynos are needed...The 4wd dyno has to have both axles connected as one...otherwise the 4wd system of the 996TT wont cooperate resulting in broken front diff or burned clutch...Have that in mind...
Old Mar 9, 2009 | 07:50 AM
Neil A's Avatar
skandalis447 thanks for the tip something for me to keep in mind as i know there arent many tuners in Scotland that work with Porsches. May be easyer to pick one i trust even if they only have a 2wd dyno and run it with the output shaft disconnected.
Lowtush
Jan 25, 2022 10:48 AM
Jul 29, 2019 11:13 AM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
The Oss
Aug 24, 2015 08:19 PM
