normal running temperature
Old Mar 29, 2009 | 11:01 PM
jeff4774's Avatar
jeff4774 is infamous around these parts
while having exhaust replaced, the shop guy try to remove the plate that pushes/separates the exhaust and the engine, in anycase, a hose came lose and about 1/2 gallon of coolant came out before he can tighten it back to stop the leak.
i did a search on coolant and see what coolant i should use, and was keeping an eye on the temperature gauge to make sure it was not over heating due to lack of coolant...
temperature reads about 180-185,
is this the a correct temperature for normal, no agressive driving?
and should i be worried about air pockets in my coolant/cooling lines?
thanks in advance
jeff-
Old Mar 30, 2009 | 07:26 AM
g8rdmd's Avatar
g8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to behold
My temp gauge usually runs just north of 180, so I'd say you're about normal... Can't answer to the air bubble question though
Old Mar 30, 2009 | 08:01 AM
boca996tt's Avatar
boca996tt is just really niceboca996tt is just really niceboca996tt is just really niceboca996tt is just really nice
mine runs about the same #'s hard to get an exact on that type of gauge
Old Mar 30, 2009 | 09:40 AM
Alpha's Avatar
Alpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud of
For regular driving when fully warmed up, the needle is along the right hand edge of the "0" in the "180" for me.
Old Mar 30, 2009 | 09:43 AM
ttboost's Avatar
Same here...
Old Mar 30, 2009 | 09:51 AM
JoelPirela's Avatar
JoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond repute
Buy the porsche coolant and run the car with the purge valve open (the black cap with the metal loop) after a while, stop the car, let it cool and fill the coolant tank with what is needed. Maybe repeat 2-3 times and you're done.
joel
Old Mar 30, 2009 | 09:53 AM
9Eleven's Avatar
9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute
Mine will not warm up in cold weather (under 50 degrees). It sits at 140 to 150. Had everything checked, sensors and thermostat. All in working order, what gives?
Old Apr 1, 2009 | 08:27 PM
jeff4774's Avatar
i will try as you suggest
JoelPirela
i also what happens if i have the air pockets in the coolant line?
i will read the other posts for the answer as well.
Stuart@VelocityAP
Sep 1, 2021 02:04 PM
Jul 29, 2019 11:13 AM
orbelo
Aug 30, 2015 12:26 PM
ECS Tuning - VW
Aug 21, 2015 09:11 AM
