DIY for Clutch Accumulator W/Pics...
Old Nov 19, 2009 | 07:37 AM
  #46
mt10argyll's Avatar
mt10argyll is infamous around these parts
Yes top write up replaced mine today with your post
max
Old Aug 23, 2012 | 09:31 PM
  #47
BMiller33's Avatar
BMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond repute
My accumulator loosened on me (https://www.6speedonline.com/forums/...-seal-diy.html), I tightened by hand but plan to use an oil filter strap. Should I replace and bleed, bleed only with existing accumulator, or just tighten and check fluid level without bleeding? Clutch has shown no signs of any problems. Thanks.
Old Aug 23, 2012 | 10:39 PM
  #48
mt10argyll's Avatar
I would just tighten and check fluid level. Their should be no need to bleed the accumulator.
Max
Old Aug 24, 2012 | 03:46 AM
  #49
S4corrado996TT's Avatar
S4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really nice
Thumbs up
Thanks for such valuable posting! Great job!
Old Aug 29, 2012 | 08:54 PM
  #50
BMiller33's Avatar
Here is how I tie wrapped my coolant lines which provided great access to the CA.
Tightening the CA was still a PITA, I used my hands with rubber gloves (be sure the CA is cleaned, I used brake cleaner on the outside). I couldn't get my 27mm wrench in there and the filter strap didn't seem to do much so I squeezed in a small pair of vice grips (I pre-set the grip to the fitting before I installed).
Lastly I found it easy to use a long universal extension with a 10mm end to get the coolant line bracket screw started, see below.
After following the proper topping off procedure it was done, no leaks. Fairly easy job, I think it took longer to get the car on jack stands and get the wheel off.
Old Aug 29, 2012 | 11:01 PM
  #51
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Mike,
As always a very informative write up. I've had mine replace once and didn't even know it had failed. Does driving the car with a failed accumulator cause accelerated wear on any other components? When it's time to replace the clutch assembly, I think I'll do the GT2 convertion to get rid of the entire issue in the future.
Old Apr 19, 2014 | 01:48 PM
  #52
CBRacerX's Avatar
CBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to behold
I just did mine, the part on the car was 22mm and the replacement from Suncoast 27mm. I had the pleasure of making two custom wrenches.
No bleeding required.
Old May 2, 2014 | 11:27 PM
  #53
breakfast's Avatar
breakfast is infamous around these partsbreakfast is infamous around these partsbreakfast is infamous around these parts
100% same for me(2003 MY ).Took more time making the tools.
Absolutely no need to bleed. Service manual doesn't call for it either. I pumped 10 or so times. Started car. Let idle for a little bit. Turned off. Clutch was good. Checked levels. All was fine.
The accumulator I pulled off had a 993 starting part number. Probably original.
Much appreciated for this thread and all the others.
Old Aug 26, 2015 | 04:31 PM
  #54
xbox_fan's Avatar
xbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond repute
Anyone knowing how much the new accumulator weights? Trying to sort shipping through a friend (air travel bag weight limits)
Old Aug 26, 2015 | 06:09 PM
  #55
32krazy!'s Avatar
couple lbs no more. its like a big hollow ceramic ball
Old Aug 26, 2015 | 07:53 PM
  #56
'02996ttx50's Avatar
you might want to check w the supplier/vendor as there is some very strange shipping prohibition on this one item. much like an airbag steering wheel might have, because of the charge needed to activate it. its weird. if you call pelican parts they''ll tell you about it more thoroughly.
some vendors wont ship it.
Old Aug 27, 2015 | 12:38 AM
  #57
xbox_fan's Avatar
thanks, ended up finding it on an Swedish online store, so price diff isn't big enough to ship from the US.
Old Jul 4, 2018 | 10:56 AM
  #58
alpinewhite's Avatar
alpinewhite is infamous around these parts
What is the approximate torque spec on the accumulator?
Old Jul 7, 2018 | 05:40 PM
  #59
jpflip's Avatar
22.2 ftlb....Repair manual page 677.
Old Jul 7, 2018 | 10:04 PM
  #60
vogz's Avatar
vogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond repute
No way you're getting a torque wrench on that thing. I went about 1/16th of a turn past hand tight. I loosened it again just to test how tight it was and it took about the same amount of force to loosen as the original did.
carbonjim996TT
Sep 20, 2015 08:14 AM
NRoy7
Sep 19, 2015 06:59 AM
I-Man
Sep 17, 2015 05:31 AM
sparks
Sep 8, 2015 03:03 PM
ship it
Sep 7, 2015 10:49 AM
