AWD reliable w/ our 650-700 kits?
Subscribe
Apr 27, 2009 | 12:19 PM
Are you guys busting your diffs or having any related issues as a result of running more HP on our cars? Let me know!
Reply
Apr 27, 2009 | 01:52 PM
jsanch21 have any more photos of your car it looks sweet
Reply
Apr 27, 2009 | 01:57 PM
Nothing destroyed but clutches!!
Reply
Apr 27, 2009 | 03:05 PM
No problems on my GT700
Reply
Apr 27, 2009 | 04:47 PM
Differential and transmission failure seem to have a direct correlation between driver and clutch engagement or wheel hop. Stay away from repeatedly dropping the clutch from a standstill or inducing huge amounts of wheel hop and you should be ok. I have been running around(in RWD) for a few thousand miles now at between 570 wheel hp and 650 wheel hp with no issues whatsoever. This is with a rather aggressive clutch setup.
Justin
Reply
Apr 27, 2009 | 05:02 PM
I haven't had any problems either.
Reply
Apr 27, 2009 | 09:13 PM
No problems either....also make sure your wheel ratios are within specs if you have upgraded rims/tires.
Reply
Apr 27, 2009 | 11:15 PM
Thanks for your input guys! I will be keeping my car stock and posting more pics soon! Cheers!
Reply
Apr 27, 2009 | 11:32 PM
What about those with a Tip? How much power can that tranny handle, if you six-speeders are blowing clutches?
Reply
Apr 28, 2009 | 05:14 AM
am running the Agency Power 600HP K24/18G Kit on my 01 996tt tiptronic its great asked the tech and he said the tip could handle up to 650-700 after that u need a torque converter and some other stuff
Reply
Apr 28, 2009 | 12:02 PM
No driveline problems of any kind with my car after a fairly high power build. Been running well over 2 years.
Reply
Apr 28, 2009 | 12:58 PM
Quote: What about those with a Tip? How much power can that tranny handle, if you six-speeders are blowing clutches?
9ff does some cool stuff for the Tip. You should contact them if you have any questions. I have ridden in a high HP car with the 9ff modified Tip and it was pretty sweet.
Reply
Apr 28, 2009 | 01:53 PM
Quote: 9ff does some cool stuff for the Tip. You should contact them if you have any questions. I have ridden in a high HP car with the 9ff modified Tip and it was pretty sweet.
Good call. I'm not there yet, but was just curious. I get bored with cars quickly, so each incremental change is appreciated more than just doing it all at once. (For me.)
Reply
Subscribe
