996TT Internal Mods?
Old Apr 27, 2009 | 08:16 PM
DEEPBLUE's Avatar
DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !
I am contemplating doing some internal mods, I know there is a huge range between basic and advanced kits including machining, what are some options and associated costs?
I know evoms has an internals kit, are there other competing vendors?
Thanks.
Old Apr 27, 2009 | 08:35 PM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Thanks.
Do yourself a favor and dont do it, stay where you are. Once you get in the engine it is a never ending series of "well, since I'm in here" type upgrades. It can and will be frustrating and expensive. Good luck, Kevin
Old Apr 27, 2009 | 08:40 PM
unvmy996's Avatar
if you do anything just make it simple dont go over board, also when you go to crazy you will loose that every day drivability a bit also.
Betim@BBIAutosport's Avatar
Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !
Basic internals would be:
Head Gasket, Head studs, and rods...
KPG, is right on about the "well, since i'm in here" theory...
Old Apr 27, 2009 | 08:44 PM
DEEPBLUE's Avatar
Wow- not what I had expected, but good advice.
These cars are very dangerous for "since I am there's"
Old Apr 27, 2009 | 09:11 PM
Dr_jitsu's Avatar
You can go all the way up to 680 whp or so on a stock motor if you do it properly.
Old Apr 27, 2009 | 09:25 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Isn't Chris Green at 700 on stock motor?
Old Apr 27, 2009 | 09:42 PM
Prche951's Avatar
KPG, speaking from experience ? I can't wait to see your monster finished.
Old Apr 27, 2009 | 09:48 PM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
Originally Posted by Prche951
KPG, I can't wait to see your monster finished.
Me too!
Old Apr 27, 2009 | 09:55 PM
KPG's Avatar
KPG
Originally Posted by joetwint
Me too!
can I wax your car? It would be an honor. BTW, my son asked where the picture of the Viper sign is that you were going to send....good thing I am not trying to change the subject
Old Apr 27, 2009 | 09:57 PM
Turbo Fanatic's Avatar
You have quite a ways to go. Upgraded turbos, injectors second fuel pump...
Most people just do rods if they do the motor. Of course there are the 1,000 HP guys... different league altogether. Me?
Old Apr 27, 2009 | 10:00 PM
joetwint's Avatar
LoL,OK ya got me there ,I will send it!Now where were we?
Old Apr 27, 2009 | 10:04 PM
joetwint's Avatar
Rods,better head gaskets,competition valve job,balancing/blueprinting and bigger studs are the minimums IMO.
Old Apr 27, 2009 | 10:08 PM
Dr_jitsu's Avatar
lets say you do the bottom end...now your car might be able to handle GT 35's, but w/ the stock crank you won't be able to rev high enough to get the most out of them. And If you do the crank you will need head work of course. Then you might as well go w/ a 3.8 stroker....
Old Apr 27, 2009 | 10:38 PM
colorinc's Avatar
colorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond repute
pauter or carrillo rods (with the carrillo u have to grind some clearance in the oil pump) the pauters clear just fine.. apr makes a good set of studs.. i replace the injectors while the motor was out a ton easier that way
tim
ps i do not have the invoice here at home but was able to look up what i paid for the studs,rods and injectors $3876.00 from todd at protomotive
