Stalling problem
Old May 15, 2009 | 06:55 PM
av996tt's Avatar
av996tt is infamous around these parts
Stalling problem
Car lugs or stalls if I blip the throttle from idle. Approx 200-300rpms above idle. It's been doing this since I got it. I've had the motor replaced with a new Porsche engine for a different problem and it still does this. Do you think it's ecu related? I have the stock program still.
Old May 15, 2009 | 08:16 PM
wross996TT's Avatar
MY and model...please...have you read the codes? That idle is too low fo sho. It can be changed in the ECU, but there may be other issues.
Old May 15, 2009 | 08:26 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Tough call....what plugs are you using?
Old May 15, 2009 | 10:57 PM
ard's Avatar
ard
New engine? That would rule out anything in the engine. At least for an first shot, internet based diagnosis...
I'd look at your throttle potentiometers- not sure but there are probably ways to interrogate that with a diagnostic computer as well as a procedure for calibrating them...
A
Old May 16, 2009 | 12:49 AM
996garage's Avatar
996garage is infamous around these parts996garage is infamous around these parts
You don't have a light weight flywheel do you?
Old May 16, 2009 | 01:41 PM
av996tt's Avatar
wross- it's a 2001 966 TT. I haven't had the codes read. I will mention it to the dealer the next time I need to go in. It's not a real big deal. It doesn't cause me any problems, as I don't blip it unless I'm trying to upshift or downshift...and then I'm moving so it doesn't effect anything. I just wasn't sure if this was a normal, as I just bought it last August and I'm getting to know it. I thought it would resolve itself after the new engine, but I guess it didn't.
art4iza - since it's a new engine from porsche, I would guess the oem plugs.
996garage- yes i do, I had it installed the same time I got the new engine installed. Before when I had the dual mass flywheel, it would just lug a little, but now that I have the lwfw it will lug and then stall 50% of the time. However, this only happens when I blip it lightly. If I rev it to around to 2-3k...then it doesn't lug. rev's just fall normally.
As I said before, I didn't know if this was normal for this model or if it was something else. With the new motor, I'm inclined to think it's the ECU.
Old May 16, 2009 | 04:36 PM
BLKMGK's Avatar
The LWFW is causing at least some of the issue, it lacks the inertia that the OEM one does. Tweaking the ECU will fix that part of it. It might be helpful if you could explain what you mean by "lug" when you attempt to blip the throttle - it doesn't rev?
Old May 16, 2009 | 04:48 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
have beemtold that your ecu will learn the flw change ,i have one with prob
Old May 16, 2009 | 09:27 PM
996garage's Avatar
Suddenly after I put in a LWFW, I would potentially stall anytime I got off the throttle quickly. You definitely have to change your driving a bit to avoid the stalling. (ie, letting the engine rev down a bit before pushing the clutch in when stopping) I have a UMW flash, and Kevin was able to give me a program fix to help with the stalling problem.
Old May 16, 2009 | 09:42 PM
oak's Avatar
oak
common prob w lwfw.
Old Mar 7, 2014 | 09:01 PM
IITURBO's Avatar
IITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to all
I'm experiencing the same issue, but I don't have a lwfw. ECU is definitely flashed but I don't know by who. Any suggestions? I also pulled he MAF and sprayed it with MAF cleaner, but it didn't look dirty anyway.
Old Mar 15, 2014 | 09:58 AM
Teoulmoon's Avatar
Teoulmoon is infamous around these parts
I'm a pretty new owner, but I also have a lwfw I have the same issues. I don't stall anymore because I just make sure the revs don't drop too low. Sometimes the ecu blips the revs when I don't expect it but I hear it's normal.
Old Mar 15, 2014 | 11:27 AM
Whereitsat's Avatar
Whereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond repute
If you have a LWFW, have your idle raised slightly to reduce the stalling. As for stalling in general from throttle blips, I had this issue. The answer was repairing a vacuum/boost leak. I had small leaks on a couple hoses. Drivers Source tracked them down and the issue went away. Boost went up .2 bar as well. It was easy because I didn't do it.
cockneymike
Oct 22, 2015 06:00 PM
vogz
Sep 19, 2015 01:02 PM
Blue Chip
Sep 10, 2015 07:07 AM
falter
964 Turbo
Sep 4, 2015 01:41 PM
falter
964 Turbo
Sep 4, 2015 01:37 PM
