DIY or not...DV's?
Old Jun 1, 2009 | 06:38 PM
g8rdmd's Avatar
g8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to behold
DIY or not...DV's?
I believe I'm getting the Canadian Goose TT Syndrome, AKA honking on acceleration
I've read through the threads and know that the stock DVs (I've got a non-X50 with 46,000 on the odo) don't last that long. I'm looking probably at the Baileys or similar to replace them. Question is, though, is it a DIY (and is there a thread with instructions)? Or is this something I have to have my mechanic do? I prefer to do as much as I can myself just for the satisfaction of it all. Thanks guys
Old Jun 1, 2009 | 06:43 PM
justinmm2's Avatar
justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !
Old Jun 1, 2009 | 07:11 PM
raineycd's Avatar
I did them recently and it was not super hard, it is just tight and hard to get everything back together. Just takes some patience and determination! I put in some Forge DVs that were recommended by many people on this forum.
https://www.6speedonline.com/forums/...er-valves.html
Old Jun 1, 2009 | 07:36 PM
g8rdmd's Avatar
As Jim Carrey would say B E A utiful
Old Jun 1, 2009 | 07:54 PM
Soul's Avatar
Soul is infamous around these parts
I also did it myself not long ago (Forge DVs). Took me about 1.5 hours and a bit of skin but not hard to do! (My DIY skills are very basic)
It really is a tight fit though, as they're a little bit bigger than the original plastic ones.
Old Jun 1, 2009 | 08:08 PM
g8rdmd's Avatar
Does anyone have any experience with the Agency Power adjustable valve? I guess it's a single replacement instead of putting in 2 valves...
http://www.vividracing.com/catalog/a...5-p-35830.html
Is it just a gimmick, or does it really work--any problems replacing 2 valves with the one?
Old Jun 1, 2009 | 11:18 PM
Alpha's Avatar
Alpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud of
I recommend replacing the stock F-hose with a silicone version while you are replacing the DV's, since it is minimal extra work to do it, and it will be good preventative maintenence. A new silicone F-hose plus making sure all your connections are tight after DV replacement will prevent a post DV install boost leak. The DV towards to front of the car took me a very long time to figure out how to get out, since the clamp was facing forward (to the front of the car).
Old Jun 2, 2009 | 01:54 AM
smistry007's Avatar
smistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond repute
it is easy to do. make sure you have some gloves and also get a set of clamp- pliers.
Old Jun 2, 2009 | 06:34 AM
jpflip's Avatar
https://www.6speedonline.com/forums/...mble-mods.htmlI did it about a month ago and decided to lower the engine by about 2 inches. It is a very simple thing to do and it help a lot to get more access.... second links: https://www.6speedonline.com/forums/...tt-engine.html
Old Jun 2, 2009 | 12:12 PM
rolfjahn's Avatar
rolfjahn is a splendid one to beholdrolfjahn is a splendid one to beholdrolfjahn is a splendid one to beholdrolfjahn is a splendid one to beholdrolfjahn is a splendid one to beholdrolfjahn is a splendid one to beholdrolfjahn is a splendid one to behold
g8rdmd-If you need complete instructions/pictures I will post in detail to lower the engine safely 2-4 inches-Rolf
Old Jun 2, 2009 | 12:44 PM
Yves's Avatar
Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !
I received help from a firnd and it really helped.
Just a matter of having an extra pair of hands to wrestle down some of the non-cooperating components
You will also need a pair of needle pliers to deal with the clamps.
Old Jun 2, 2009 | 12:57 PM
kennyjr748's Avatar
kennyjr748 is infamous around these parts
I did it with the help of a friend. I found it to be a PITA and probably would have someone else do it if I had to do it over again... but then again, I'm not much of a mechanic.
Old Jun 2, 2009 | 01:31 PM
MBailey's Avatar
I got the dealer to do it for me for 2 hours labor. I would not try it yourself unless you have experiance or small hands and lots of patience.
Old Jun 2, 2009 | 01:42 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
i did mine it was ez , well when i was finished. just take you time and allow for a cut or two(no room) get the correct tool 1st that makes it a lot more fun good luck steve
Old Jun 2, 2009 | 04:31 PM
smistry007's Avatar
dropping engine would make it considerably easier but is not mandatory....
