CEL P0021 996TT need advice
Hi,
I`m a new owner of 996TT,
I would like ask for advice,
Have you ever had experience with CEL code P0021?
P0021 Generic Intake Camshaft Position Timing - Over-Advanced (Bank 2)
I got this CEL without any reason during drive.Not always , but sometimes.
Can someone put service manual procedure (step by step)with this CEL code,
I heard it could couples reasons , cam solonoid failed or dirty,wrong timing,etc.
Thanks for help
Thanks for help
Hi Dominik, there are tons of helpful people here. I don't have the resources necessary myself to address your problem, but I'm sure tomorrow when someone who knows a bit more than me comes around they will be able to get you started in the right direction in troubleshooting this. If you are impatient, you can always try searching the forums for keywords, you might come up with what you need before then. Good luck.
Justin
Justin
thanks Justin for reply.
I found couples story like here
http://www.renntech.org/forums/index...howtopic=26691
but at the end of the day there wasn`t any real advice or information where the problem was been.
I'll try to help a fellow "Polak"
Sounds like a faulty Camshaft position sensor if you're not getting other faults and haven't messed with the engine internals by taking it apart.
Powodzenia
Powodzenia
