Dyno results
Old Oct 29, 2004 | 08:11 AM
DropGems's Avatar
DropGems is infamous around these parts
Dyno results
Got my car dynoed today and I'm somewhat disappointed. My car is an x-50 with upsolute chip, awe exhaust, Bailey dv's and k&n filter. If you guys recall a few months back, 6speed member Vinnie put down around 500whp,500ft with the same setup as me, on the same dyno. So I was wondering if you guys have any idea why my car is shy some 60-70whp from his. The guys at awe suggested that I check my wastegate setting and possibly have them adjusted as this could be one of the reasons the car isn't as strong as it should be. I need to figure out what's up here though. What do you guys think? Thanks
Here are my results....
1st run - 434.2 hp @ 6250rpm
447.2 ft @ 4500rpm
2nd run - 426.6 hp @ 6500rpm
463.0 ft @ 4500rpm
3rd run - 431.7 @ hp 5000rpm
473.7 @ ft 4500rpm
Here's a poor quality pic of the graph on one of the runs.
By the way, Mike at AWE is the man, real nice guy. Mike, I will be back there once I figure all this **** out. Thanks man
Old Oct 29, 2004 | 08:25 AM
AMG ETR's Avatar
Re: Dyno results
First thing you always check is hoses!!!! They are usually the problem.. I don't think the wastegates (unless way off) would cause that much power loss.
Evan
PS-Now that I actually look at the graph (doh ) the fact that it just leveled off and held that HP from 4500 all the way to redline would kinda point to the wastegates... I will let the real techs talk now
Old Oct 29, 2004 | 08:31 AM
Mr Kram's Avatar
Mr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond repute
Is this a dynojet? I was able to put down 448/497 on a standard TT with Upsolute and Remus, stock air filter.
Old Oct 29, 2004 | 08:38 AM
DropGems's Avatar
No, this was done on an awd mustang dyno.
Old Oct 29, 2004 | 12:13 PM
DropGems's Avatar
Re: Re: Dyno results
Evan
Real techs where the hell are you? This is my first dyno ever so help a clueless kid get his turbo numbers up to par! ha
Old Oct 29, 2004 | 09:05 PM
PorschePhd's Avatar
There are so many variables it is really hard to say what the issue was or is. Do you know what boos levels you were running? The wastegate adjustment could be in need., the octane of fuel. Dynos from one car to another are hard to do. Dynos should be used as a tuning tool not a comparison to the car like yours. I would say if all the above was on target you have a different program then the other car.
Old Oct 29, 2004 | 09:21 PM
BCS996TT's Avatar
BCS996TT is infamous around these parts
You're definitely off.... I was at 437AWHP/445AWTQ with standard upsolute/K16 turbos/exhaust.
This was done at AWE as well.
Old Oct 29, 2004 | 09:27 PM
RDH's Avatar
RDH
RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !
Check your gates for adjustments first, then look for leaks...re dyno for results. If no real changes, send your ecu back for the correct program along with your dyno results of course....
Old Oct 30, 2004 | 01:24 AM
DropGems's Avatar
I know there are many variables when on a dyno but I expected I would be a lot higher as most chipped k24s with exhaust hit close to 500whp from what I've gathered. The chip program is the same, I'm using the upsolute k24 program. 94 octane fuel.
Old Oct 30, 2004 | 01:32 AM
Josh/AWE's Avatar
DropGems-
It was cool meeting you as well.
I would suggest a call to Upsolute and find out what to set the wastegates at. I know what we use for the GIAC programs, but it may not be the same.
Once we do that, we will pressure test the system to see if there are any boost leaks.
Once this is done, we re-dyno.
Don't worry. I'm sure there is going to be a simple and reasonable explanation.
Keep me posted.
Old Nov 22, 2004 | 08:36 PM
ypshan's Avatar
ypshan is infamous around these parts
DropGems,
Did you ever get a resolution? Can you tell us what happened?
thanks.
Old Nov 22, 2004 | 09:54 PM
DropGems's Avatar
ypshan, no not yet. I've been emailing upsolute questions regarding specific wastegate settings. I assume it's either the wastegates or a boost leak. Once i get the lowdown then hopefully this will be resolved soon...
Old Nov 23, 2004 | 03:15 PM
JC996TT's Avatar
JC996TT is infamous around these parts
What boost are you hitting?
Old Nov 23, 2004 | 03:35 PM
Blazin Civic's Avatar
Blazin Civic is infamous around these parts
Creat curve. I wish I had a powerband like that.
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
TitanMotorsport
Nissan GTR
Sep 23, 2015 03:25 PM
webcarconnection
Sep 21, 2015 10:54 AM
