Short Shifter
Old Nov 1, 2004 | 08:05 AM
95RogueM3's Avatar
95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of
Short Shifter
hey Guys,
I am debating whether or not I should buy my father a short shifter for his '02 996tt for his birthday. I have seen a few that seem to be on the market..is there anyone that is considered the best, ie least notchy, most reasonable throws.
For reference this is a man who is not into modifications, he likes sports cars and has had alot from Lotus, Ferrari, multiple Porsches..but hasnt modified any..unless you count buying the Porsche umbrella that fits into the passenger door.
Back on topic....when he saw a window sticker on an '03 tt when we were picking up our Cayenne, he noticed and seemed to like the idea of the SSK that Porsche provides but I am willing to bet that costs too much and as a college student I am looking for quality on a budget.
If you guys could recommend some shifters that you have tried and liked as well as any to avoid i would appreciate it. Also..if you could mention if it is an in-cabin install or an underneath and the cost associated with installs (I dont want to buy one that he needs to spend $300 getting installed or more).
My m3 short shifter cost $325+$60 for installation....is that what I might expect for the 996?
thanks
-Richard
Old Nov 1, 2004 | 08:18 AM
TT Surgeon's Avatar
B-M, takes less than 1hr to put in yourself. brandywine Porsche sells them for 199.
Old Nov 1, 2004 | 10:14 AM
neil.schneider's Avatar
neil.schneider has a spectacular aura aboutneil.schneider has a spectacular aura about
I second that. Under car kit is very easy.
Old Nov 1, 2004 | 10:43 AM
FineProperty's Avatar
FineProperty is infamous around these parts
Is the short shift kit at the shifter...or somewhere else in the linkage (I understand it's under the car install)?
And, more importantly, does it make it notchy? I've noticed on one kit that I can shift a long throw quicker than having to divert my attention to 'forcing' a short shift to the gear. The syncros must have longer to do their job.
Old Nov 1, 2004 | 12:28 PM
Zippy's Avatar
Notchy Good!
Old Nov 1, 2004 | 01:51 PM
msindi's Avatar
There are 2 SSK kis for the 996TT (both made by B&M too)
1) the in-car short shifter that is now offered as a factory option (made by B&M repackaged by Porsche at almost 3 times more $$$)
2) The under car short shifter (made by B&M repackaged by RUF, etc. also for 3 times more $$$)
Th in-car is not reversibale without buying a new shifter tower assembly....Also, if you go the in-car route (what i have had on my last 3 996s) be sure to INDEX the cables before remocing the sock shifter (actually, there is a way of doiing it without disconnecting he cables at all )
Old Nov 1, 2004 | 07:13 PM
JASCLASS's Avatar
JASCLASS is infamous around these partsJASCLASS is infamous around these parts
Originally posted by Zippy
Notchy Good!
Old Nov 1, 2004 | 10:19 PM
Poursha's Avatar
Poursha is infamous around these parts
I have the B&M under car SSK which is great. RUF and TechArt also sell under car kits (which look identical to B&M except different colors) but they're 2X - 3X more expensive.
Here's a thread with info/pix:
https://www.6speedonline.com/forums/...&threadid=8418
Old Nov 1, 2004 | 11:26 PM
Greco's Avatar
Greco is infamous around these parts
What are the differences between the under car and the in-car kits? Does one provide better/shorter throws? Is the end result the same?
Old Nov 2, 2004 | 03:15 AM
Poursha's Avatar
I went with the under car B&M because I had read on several boards that some people found the in car kit increased the shifting effort too much, and resulted in notchy shifting--and some had even removed them because of this complaint.
One guy uninstalled the in car kit because of the notchiness, and installed the under car kit and loved it, so I went that route and am very happy. You can set the throw reduction to 10%, 20% or 30% (mine is 30%). The throws are noticeably shorter and much more precise than stock, with a slight increase in shifting effort due the physics involved (although after a short while it's not noticeable), but not notchy in the least. It also leaves the left/right throw unchanged, so you won't mistakenly downshift from 5th to 2nd when you meant to hit 4th (the in car kit reduces left/right throw).
If for some reason you want to go back to stock, it's much easier with the under car kit.
Old Nov 2, 2004 | 03:30 AM
95RogueM3's Avatar
Thanks for all the input guys.
do you mind if I ask what Akkurat charged for install, Poursha?
thanks.
Richard
Old Nov 2, 2004 | 04:39 AM
Poursha's Avatar
Akkurat did a great job, and at a reasonable price--I highly recommend them.
steve harris
Jun 10, 2017 12:17 AM
turb0terr0r
Sep 29, 2015 05:47 PM
bongnation
Sep 25, 2015 02:58 PM
997zen
Sep 7, 2015 07:13 AM
